Stainless wheel covers
Will these push on caps work on the factory 18 hole steel wheels? Not sure if the wheel is as deep as the older style wheels that used to use these types of caps.
16" Full Moon Hot Rod Racing Disc Hub Caps Solid Wheel Covers Rims New Set of 4 | eBay |
They should work, here's a thread on "Full Moon" style wheel covers...
https://www.chevyhhr.net/forums/cana...hubcaps-25444/ |
These are for standard wheels, not FWD wheels, call them and ask for the correct rims for your HHR
Oldblue, good catch on the wheel covers, not sure how I miseed that in the eBay ad.:red:
According to the info on this site, the 18 hole steel wheel is a standard wheel. The depth measurement matches their info. So, according to this, they should work. Styled Versus Standard Steel Wheels
Well if you are confident in your research and findings, order up a set!
1 Attachment(s)
Turns out my research and findings were correct, as opposed to listening to someone that said they would not work without any info to back it up. Data, specs, and pictures had all of the answers. Attachment 22620
Nice, I have those too
