Switching out aftermarket wheels and tires on HHR?
Old Jun 10, 2019 | 10:43 PM
Mckobe's Avatar
Question Switching out aftermarket wheels and tires on HHR?
Hi Everyone
I picked up a panel. Car is very clean
There are some aftermarket wheels. I pulled one off and it's 17x7.5 with a 42 offset. Tires are 235/45/17
I went to tirerack and like that they can mount, balance and tpms everything, and all i have to do install them
I'm thinking about going with a 17x8 with a 40 offset. I definitely don't want any rubbing, but i'm thinking it will have the same distance from the hub as what's currently on the car
Am i safe going with 17x8 40? I would still go with the 235/45/17 tire. Can i even to to a 38 offset, which i assume would be closer to the fender as far as more of a flush look?
Thanks
Old Jun 11, 2019 | 12:43 PM
Welcome to the site, measure two or three times, buy rims and tires once.
Old Jun 11, 2019 | 05:01 PM
Mckobe's Avatar
Unfortunately your response doesn't help
To purchase from tire rack to measure, and return 2-3 times would be such a hassle and so so so much time wasted
I'm looking to buy just once, which is why i asked the question before i buy
Old Jun 11, 2019 | 05:19 PM
When you modify or change from the original equipment, it's hard to say what will "fit". Aftermarket wheels can have varying specs. Wheel thickness, offset and such just add to the guessing game.
Oldblue's advice is spot on since you don't give the exact wheel and tire manufacturer.
Buying from Tirerack is fine for a tried and proven size combo.
Old Jun 11, 2019 | 06:15 PM
I’m sorry you miss read my response, you measure the dimensions of your car. Drum or rotor surface to the fender .
a 42 mm offset for the stock rim is not the same as a wider rim. There are other things to look into . I believe there is a wheel finder on the Tire Rack website.
Thanks measuring three times, buying once.
https://www.tirerack.com/wheels/resu...&package=false
Old Jun 11, 2019 | 08:20 PM
There's more to it than just looks. Here's an article https://www.lesschwab.com/article/wh...el-offset.html
Old Jun 11, 2019 | 08:41 PM
Oopps ! I see RJ already has this covered.. I missed it..
Just a visual aid. The outer edge of the rims are on the RIGHT of each image..
Old Jun 12, 2019 | 07:23 AM
Ok, I’m out.
Old Jun 12, 2019 | 05:27 PM
Blue_SS's Avatar
Use an online calculator. It is part of how I won an autocross championship in 2010. You will have to get off your arse and take some measurements, but it's perfect. Measure many, buy once.
puppysmum
Mar 21, 2023 07:45 AM
kodythekasper
Feb 4, 2015 04:43 PM
Medic7419
Aug 31, 2013 10:21 PM
nybble
Fuel Economy - Hypermiling
May 4, 2013 10:06 AM
Rikki Sixx
Maintenance and Upkeep
80
Apr 7, 2013 07:23 AM
