Originally Posted by ChevyMgr
(Post 418915)
No sensor in the spare. And there is no room in the compact wheel to install one. It wouldn't matter if it had one. It would still have to be programmed.
As much as I like these for safety and convenience, I think they are a hassle, and just something else to go wrong and cost people money they don't have. |
I'm having trouble reprogramming our '08s sensors after a tire rotation.
Following the manuals instructions of course.. After i put it into programming mode by holding lock and unlock on the fob the manual says the drivers side signal is supposed to come on. By coming on do they just mean light up or blink? All my parking lights just come on. I continued trying to program by letting out the air on the drivers front tire..no single horn blow like the manual says. After a bit I just get 2 short toots which i assume is my 2 minute time limit running out. So aggravating..I'm usually really good at figuing out stuff like this,but after about a hour trying to figure it out i'm at my wits end. |
Originally Posted by Smallblock
(Post 419770)
Following the manuals instructions of course.. After i put it into programming mode by holding lock and unlock on the fob the manual says the drivers side signal is supposed to come on. By coming on do they just mean light up or blink? All my parking lights just come on. I continued trying to program by letting out the air on the drivers front tire..no single horn blow like the manual says. After a bit I just get 2 short toots which i assume is my 2 minute time limit running out. So aggravating..I'm usually really good at figuing out stuff like this,but after about a hour trying to figure it out i'm at my wits end. Don |
Does anyone know the accuracy of these pressure monitors? My hand gauge says that my tires are at 32psi while the car's system has them at 36psi. The hand gauge I have is pretty accurate, but I am wondering if I should buy a new one.
Having read all the way through this, and not seeing the answer I need.. can you take the TPMS from one set of rims (my Shadow Edition rims) and transfer them to a set of LS Steel rims (my soon to be rims)?
Kevin |
You didn't read very thoroughly then. It is stated a couple times that you can, but you may need to replace the valve stem.
Do apologize, I must have missed it reading when tired. Thank you.
Originally Posted by Krusty
(Post 418949)
I bought a set of 4 for my winter rims (new in boxes) off of Ebay for under $40. They're made by Schraeder, who I believe is the OEM maker for GM.
Krusty. |
Originally Posted by greendot
(Post 548183)
I had searched ebay and did not find this low a price. Can you provide the vendor's ID so I can search them out? Were yours rubber or metal? I suspect that the rubber ones came with steel wheels and the metal ones on aluminum rims
(Post 419770)
