205/65r15
Old 10-26-2008, 07:11 PM
andoll83's Avatar
205/65r15
205/65R15
How do I know if these will rub on the wheel well?
andoll83 is offline
Old 10-26-2008, 07:31 PM
tireman1554's Avatar
They will not. They are close to the same diameter as the 205/55R-16.
tireman1554 is offline
Old 10-26-2008, 07:54 PM
andoll83's Avatar
They will not fit, or they will not rub on the wheel well? I want to be absolutely sure so I don't have to eat the shipping cost if I have to return them
andoll83 is offline
Old 10-27-2008, 09:00 AM
What size ar you running now, and why are you downsizinf to 15"?
Old 10-27-2008, 10:31 AM
Cokeybill's Avatar
Check here. scroll down for the info!!
http://www.rims-n-tires.com/rt_specs.jsp
Cokeybill is offline
Old 10-27-2008, 07:04 PM
andoll83's Avatar
I'm currently running 215/50R17... studded winter tires were expensive in that size, so I bought 15" steelies and a set of studded 205/65R15 Winterforces, which turn out to be the only about .1" bigger in circumference.
andoll83 is offline
Old 10-28-2008, 09:36 AM
You should have no problem. P205/60R-15 would be better. I currently run P245/45-17 on mine which are taller and wider than stock with no problems.
Old 10-28-2008, 10:25 AM
hyperv6's Avatar
Will the 15 inch clear the caliper? My 16 inch are close.
hyperv6 is offline
Old 10-28-2008, 04:58 PM
badboy69's Avatar
I have that exact size tire on 15'' rims. The rims are from a malibu, and they fit perfectly on the ls version like mine, I due not know about the other models. the tire's are not ribbing anywere. and rims are clearing the front calipor
badboy69 is offline
Old 10-28-2008, 08:02 PM
jbbadboy's Avatar
Hmm....I was looking at getting 16" steelies with winter tires for my LT (currently running the stock 17" wheels) but maybe I can save a few more dollars going with 15's.
How weird does it look going from 17" wheels to 15" ones I wonder?
jbbadboy is offline
