Tire Rotation
I hate useless gizmos like the TPMS, and hate the government agency that impose these gizmos on us, even more......
A driver that can't check the tire pressure on his car, once a month, shouldn't drive IMHO. PERIOD.
To hell with the TPMS system, me says.
Long live the simple tire pressure gauge. Don't need to read a 3 page instruction manual to use it
I beg to differ. I know for a fact I've had more than one car where the owners manual recommended tire rotation front to back, etc. No longer owning those cars, I can't quote page numbers or specifics but I do believe my '97 Firebird was one that stated as such.
And yes it was in the late '70's when I did sell tires, so I was wondering based on my experience then.
As I recall, I've had "directional" wheels also might be where I remember some of this as an item. That was on a 4 wheel drive pick-up.
You are correct. Some vehicles come with directional wheels or tires which should only be rotated front to back. Some have different offsets Like the 80's Camaro and Firebird which could only be rotated side to side. Some Like the Corvette and Acura NSX Can never be rotated. Truth is; any different position you put your tires in helps to maintain an even wear pattern, but you also need to maintain proper air pressure and vehicle alignment otherwise rotating is useless.
That was when getting a 30,000 mile (pro-rated) tire was a plus, now that's just basic stuff, I don't even think you see that low a warranty any more.
I learned way back when, actually worked at a "Service Station" ('70-'75) you don't see those any more, rotating was real important for tire life.
Dealer is giving me a hard time over warranty visit to update RCDLR to update manual relearn procedure. I put my factory wheels back on and rotated. I trie the relearn procedure from the manual multiple times, draining & refilling the tire, only to have the system time out after 2 minutes. The dealer says they will reset with their tech tool, and charge me $51.50. I argue that this is a warranty issue, as the relaern feature is a user servicable item that is not functioning properly. They argue that they use a tech tool, and don't do the manual method. I argue about what about the next time I rotate tires.Using their reste tool doesn't solve my problem. I also gave them copies of the TSG from this site, with instructions, but they still want to treat me like and idiot and charge me $51.50. I am writting to GM to warn of either a warranty problem, or service issue that they are treating as a proprietory problem. If I change tires, I have to go back to them each time?
i got a question , maybe silly...my rear tires are showing very very little signs of wear..i have not rotated for 45000 miles..yea i'm slack....the fronts are wearing out...i wonder if it would just be cheaper to relace the front and never rotate???..i know that this is not recomended...but since noticing how there is very little wear on the rear , it really got me wondering. if rotating will benefit tire sales more than it will benefit consumers???...it may be hard to calculate the true cost...also i can't believe these oem firehawks still have tread on them at 72000.....why put them on the front if they are not even showing any wear
???...i may test my theory on my next set..i allready kinda did , but not on purpose.
....if anyone has run staggered sets of tires , like on corvettes , they may be able to say if i am right , or totally insane...but also consider that alot of vehicles with staggered tires are mostly rear wheel drive and performace vehicles.
Radial tires are rotated front to rear on the same side. If you criss-cross 'em, you change the direction of rotation and you'll rip up the treat. Old bias ply tires you could do the X rotation; but NOT with radials.
