Tire size 215-60-17?
Has anyone put a 215-60-17 on an HHR?
The taller tire sure would make it ride smoother and save front end parts better mileage also! :smile: I know 215-55-17 will fit which is better than stock. |
Click on tools and the rim and tire calculator to see if that will fit
Won't fit. Too tall. Will hit the bottom strut perch.
Check this chart! Your tire diameter needs to be 26.2 inches or under!
http://www.importtire.com/itphotos/doc-od-ref.pdf |
Thanks.
