Torque thrust question
i recently purchased a nice used set of torque thrust wheels from a HHR. I am trying to figure out the correct lug nut to use. Any help would be appreciated
What is a torque thrust wheel? What would be the difference in lug nuts?
I don't know. |
They are made by American racing wheel . I have seen other members on threads discussing them but could not find info. On the recommendation for lug nut style.
Lug nuts can be acorn style with a concave mount, a concave style with washer, or flat mount with washer. The flat style with washer can come in different lengths so they are concentric to the hole opening in the wheel. |
Have you tried http://www.americanracing.com/ ? They sell the nuts, I assume they would be able to match them up.
Many times you can tell by the hole the stud comes through. If it's a round hole with an acorn style seat, then acorn style lugs. If it's oval or flat, then it should be the washer style. For length, you'll have to measure.
