TPMS for steel wheels
Old 12-09-2017, 06:11 PM
Steve Karadi's Avatar
I have a 2009 2 LT and I want to change my wheels to 16" steel smoothie. I understand that the toms sensors from my stock alum rims won't fit. Is that correct ? Where can I get sensors that will work ? Thanks
Steve Karadi is offline
Old 12-09-2017, 06:16 PM
Hi Steve, to the forums!!
I think you mean TPMS,
Your sensors, if original, are very likely near the end of their life anyways(non-replaceable batteries). You should be able to get the proper sensors from many sources. EBay, tire shops, Amazon, etc.
RJ_RS_SS_350 is online now
Old 12-09-2017, 07:32 PM
Technical Moderator
I don't know any reason they won't work. What reason was given?
They are available everywhere auto parts are sold. Just be sure they don't think you have a PT Cruiser.
donbrew is online now
Old 12-09-2017, 07:59 PM
I read on a different thead that all I have to do is change the valve with one that matches the new rim and has a nut in it to attach the sensor to it. You're right about getting new sensors too.
​​​​​​​To answer the other guys comment... the valve stem is different for aluminum wheels vs steel wheels. The thickness of the metal is not the same
Old 12-09-2017, 10:10 PM
Technical Moderator
Well then get rubber stems. The sensors are the same.
Old 12-10-2017, 08:34 AM
Steel rims ... rubber TPMS sensors stems 25920615
Aluminum rims ..metal stems 15202272
Oldblue is offline
BlackknighT
08-19-2011 07:15 PM
spotty
Tires & Wheels
05-13-2011 01:01 AM
Quick Reply: TPMS for steel wheels
