What is a good tire size for 20" rims?
Seriously, it's not a good idea to put anything other than the stock overall diameter of the tire/wheel combo.
What you are asking for could be accomplished with raising the suspension and then recalibrating the speedo and upgrading the braking system. You could be the first with an HHR Donk.
Buy an Escalade?
Apparently someone has never heard of plus sizing......
American Racing Rogue Chrome
Model: AR-673
20" x 8.5" 5x110 +35 Offset
Tires: 235/30/20
Lowered with Eibach Sportline Springs
Had to roll the rear fenders just a bit to fit. If you have a 2006 HHR you must roll/trim the rear fenders a lot.
If lowered, you can stick with a 225 width tire on a 20" x 8" wheel with the right offset, you'll probably get away with not rolling the rear fenders on a 2007 HHR.
Yes I have. Re-read what I posted.
Also, did you see the "smiley"? I was making the sugestion somewhat in jest.
As far as donks being "barf", they're not my cup of tea either, but isn't it great that we can all like differrent things!!
typically have bigger rims than a 20". IF you look on this site there are a lot of rides with 20's and they're not Donks
