hahns poo87
Old 12-20-2014, 08:36 PM
graffixx's Avatar
hahns poo87
hello all I just got my hahns turbo ic charge piping ,,,trifecta tune etc... I keep coming up with a p2261 boost control stuck code and now after a few days im getting - p0087 low fuel ail pressure going into limp mode not sure where to start would just replace the intank fuel pump but thats little devel is almost 400 bucks any suggestions thanks in advance Graffixx
graffixx is offline
Old 12-20-2014, 09:28 PM
Welcome to the site.
You should do a little diagnostics to determine where the low pressure is occurring. Since the SS has 2 fuel pumps( 1 in tank and 1 high pressure engine mounted ) why do you think it's the in tank fuel pump ?
firemangeorge is offline
Old 12-22-2014, 09:05 AM
graffixx's Avatar
when i went to the parts house they only list 1 in the tank and they said theres not one on the engine so I was mislead I guess thats a dealer item
graffixx is offline
Old 12-22-2014, 09:25 AM
graffixx's Avatar
On that note is there an aftermarket or better hp pump I should look into I didnt have this problem till I reach the 360 to 375 hp range it runs good untill I run it hard
graffixx is offline
