Newb here....Tuning questions
Old 11-13-2016, 11:06 AM
Proto X's Avatar
Does anyone have a file from a gmtu that I can open in HP Tuners as a comparison? I am looking for a little more power but don't want to load a file where I have to mix gas(e47)
Proto X is offline
Old 11-16-2016, 08:31 AM
DrLoch's Avatar
Year and is this an automatic or a stick? Have you tried the HPT site? https://www.hptuners.com/customers/login.php
they should have one.
DrLoch is offline
Old 11-16-2016, 11:13 AM
Proto X's Avatar
I have a 2009 Automatic. If anyone has a 91/93 octane tune from HP tuners that would be good too. Hptuners form didnt have one. Just looking for comparisons.
Proto X is offline
Old 11-16-2016, 01:52 PM
DrLoch's Avatar
You understand that you will need the 3 bar sensors, correct? There are a number of post here that you can get them from. I have a 2008 manual GMTU file. I have since then modified that one in a number of ways. I'm not running E47 because of availability in my area. Do you have the std version or pro?
DrLoch is offline
Old 11-16-2016, 01:58 PM
Proto X's Avatar
I have the 3 bar maps already. I have hp tuners pro
Proto X is offline
Old 11-16-2016, 02:32 PM
DrLoch's Avatar
Since you have 3 bar sensors, have you already adjusted for the sensors or do you need to do that before you install them? I'm trying to understand where you're going or what you want to do. I understand not loading an E47 file.
DrLoch is offline
Old 11-16-2016, 02:44 PM
Proto X's Avatar
I havent installed them just looking for changes in between stock, gmtu and other hp tuners tunes. I understand how to adjust for 3 bar maps. Looking for a baseline tune like gmtu for a starting point.
Proto X is offline
J'VilleHHR
09-12-2012 07:59 AM
RHHRTOYPANEL
06-20-2007 08:31 PM
ob_one
04-16-2007 09:20 AM
Money in the Bank
02-05-2007 06:21 PM
dschoeck
Mid Central
17
10-31-2006 12:04 AM
Quick Reply: Newb here....Tuning questions
