2.4l to 2.2l Swap
Old 08-15-2016, 06:25 PM
repairguy311's Avatar
2.4l to 2.2l Swap
Hello everyone. This is my first post, and I hope to get the answers I need, This project is going to happen, I just hope to have someone with some experience to advise or guide me. I have 2 HHRs. I have a 2006 with a 2.4l and an automatic and a 2009 with a 2.2l and an automatic. The 2.4l had a catastrophic failure. I dont know the cause but I can see the internals rotating without removing any covers and it is quite noisy while running. I assume it is now junk. The 2009 I am planning a v8 swap. I dont need the stock engine and trans. It seems my least expensive option to repair it is to remove the engine trans and sub frame assembly from the 2009 and bolt it in the 2006, then just plug the wiring harness in. Is it this simple? How will the wiring change over? can I just plug the replacement assembly harness into the fuse panel?
repairguy311 is offline
Old 08-15-2016, 06:47 PM
Technical Moderator
A. CVT transmission???? is this a Honda or an HHR? There were 2 choices 5 speed manual & 4 speed auto. Well, there were 2 different 5 speeds.
B. not plug n play, I don't know if you could move the ECM and the TCM might work, but then you would have to figure out what to do with the BCM and the CAN-bus.
donbrew is offline
Old 08-15-2016, 06:52 PM
Yep, I realized my mistake in the first 5 min of research. I had always assumed it was the cvt because of the PRDIL selection on the shifter. The first appearance was in the saturn vue with the chevy 2.2 and the CVT transmission.
Old 08-15-2016, 06:53 PM
So am I correct in assuming the transmissions are exactly the same? Is the wiring issue because of the year difference?
Old 08-15-2016, 08:05 PM
My mistake yes. I assumed it was a cvt. Is the wiring issues because of the year difference? Then I would guess my best option is to use the harness from the 2.4 car with the 2.2.l engine trans and subframe, then just program the computer to a 2006 with a 2.2l. Let me know if I am thinking on the right line.
h
Old 08-15-2016, 08:07 PM
Also, is there some specific time at which my posts will not be moderated, It really seems to be delaying things.
Old 08-17-2016, 09:30 PM
hhrfreek's Avatar
How can you see internals rotating while the engine is running without removing anything?
hhrfreek is offline
Old 08-17-2016, 10:17 PM
Jimmy68's Avatar
Must have a big hole in the block.
Jimmy68 is offline
Old 08-18-2016, 07:40 AM
Technical Moderator
The electronics are different between a 2.2L and a 2.4L, the harnesses are different, the 2006 has an entirely different ECM. The ECM has to agree with the BCM.
I am not sure, but it would probably be easiest to take the ECM, BCM, TCM, engine harness, ignition theft module from the donor. And then I don't know how the Restraint computers or the ABS and traction control computers would work, since they interact with the BCM and ECM.
The GM LAN and CAN BUS are probably different.
You may have trouble with the DMV, and insurance company.
Cheaper to get a matching used engine. But, you seem to be up for a challenge.
Every car I've had since 1970 has had a PRDIL, made famous on "Green Acres". Sometimes marked PRD2L. The operation of the "I" is covered in the Owner Manual, available through the link in my sig.
Only your first post was moderated, that might be because you didn't reply to an email from the admin to complete registration. On this site you have to refresh the page and sometimes back up and re load the page to see your new post.
donbrew is offline
Old 08-18-2016, 09:43 AM
solman98's Avatar
In your case, will probably be easier to put the V8 in the 06.
solman98 is offline
Quick Reply: 2.4l to 2.2l Swap
