Vent Visors
Vent Visors
I bought my 09 in July and immediately installed vent visors. The kind that tape on the outside of the window frame. Not too long after that they came out with the in channel style, which I think look a lot cleaner.
If I were to put the in channel style on my car, how hard would the outside the window frame visors be to get off, and do you think removing the tape would pull the paint off? Just looking for some opinions here. Thanks
that goo off or goof off..works great..diesel fuel works too,just make sure to rinse with soap and water..ive found even with dish soap and wifees finger nails work good too..if you heat..use a hairdryer..not a heat gun..too much heat will loosen the paint(ive learned this removing vinlyl labels on many trucks)wait for a really hot day..they should pry off easily(dont use a steel tool!!)fishing line...tooth floss..sue it like a saw..wrap sum dowel or around popsicle sticks(or a stick)on both ends..wont cut into ur fingers..
johnbegone
02-13-2008 05:04 PM
