Front Door Speaker Replacement
I plan on replacing all 4 of my factory speakers with Pioneer TS-A1684R's next week. It doesn't say it needs adapter rings but from what I can tell the box has a template on it were you'd drill 4 holes and use self tapping screws. Not really sure I want to do that so I might pick up some adapter rings anyway. I did get speaker wire adapters from Crutchfield and they included the 2006- HHR Master Sheet. I'll scan it up tonight and post it later. Gives a lot of good info and detailed pics.
On the base system, the front door speakers are 4ohm and the rear door speakers are 8ohm. I believe on the uplevel pioneer system, all are 2ohm.
I did just purchase two dynamat door kits and will be doing the front speakers.
The HHR upgraded premium pioneer system has 2ohm speakers. They arent too hard to find aftermarket. Kicker, Infinity and a few others make them.
i just replaced all four door speakers yesterday because both left channel speakers quit. i could still faintly hear the the chimes thru the tweeter so i knew the left channel still functioned. i used the old speakers as mounting flanges for the new speakers. i used a pair of side cutters to cut the speaker baskets from the mounting flange. then i trimmed the ring from the front to make room for the speaker. worked awesome. my back door speakers were 8 ohm and the front were 4 ohm. the tweeters are hooked in parallel to the front door speakers explaining why they are differrent impedance than the back. i had to reference the wiring diagram to establish speaker polarity becuase the speakers aren't marked. according to the wiring diagram, the wires don't change colour between the radio and speakers(that would be stupid). sorry i didnt take pics. spent all afternnon as it was. i also took the drivers door lock out of the door to inspect and lube it. it still unlocks improperly with the fob.
