HHR panel rear door question
Old 04-09-2014, 10:43 PM
Mutumbo's Avatar
Hello all.
My name is John. Im hopefully about to buy a 2007 HHR LS panel version. I have a question for you all. Does the LS model come with remote rear door popper on the fob? The salesperson said that the fob was lost when they got the car in, so im curious. Ive scoured the web but cant find any definitive answers. Any help or guidance would be greatly appreciated!
Thanks everyone!
Mutumbo is offline
Old 04-09-2014, 11:11 PM
zman's Avatar
Hey John,
I have an '07 and No that year did not have the rear door on fob, i think it started with the '08s.
Panels Rule!
zman is offline
Old 04-09-2014, 11:16 PM
Mutumbo's Avatar
Ok thanks! I just wanted to make sure I wasnt missing something that was supposed to be there. Guess ill have to install them. Hopefully it wont be too hard.
Mutumbo is offline
Old 04-10-2014, 01:16 AM
John- I agree with Zman, my 08 Panel was 1st year for door poppers on the fob..Good luck on your prospective purchase..
Panels Rock !
sleeper is offline
Old 04-10-2014, 02:07 AM
Mutumbo's Avatar
Thanks!
Mutumbo is offline
Old 04-14-2014, 05:50 AM
papa_jo's Avatar
my back doors on my panel stick all the time have to push button on fob and pull door at same time, both sides
papa_jo is offline
Old 04-14-2014, 10:22 AM
Panels do rock!
Boydie
Panels Rock !
Blue Beast (aka Boydie) is offline
Old 04-14-2014, 03:44 PM
Technical Moderator
As I recall, the rear poppers are on a different receiver than the RCDLR. It will not be all that easy, even if I'm wrong about that part the RCDLR will need a software/firmware update and programming.
donbrew is offline
Old 04-14-2014, 04:08 PM
Lucky's Avatar
I had a tsb done to mine for sticky rear doors when it was new. They still stick a little. The best thing I have found is to lube the weather strips for the door with spray silicone. It helps some.
Here is a link to the tsb that was done to mine but I don't think it applies to your 2010.
https://www.chevyhhr.net/forums/show...hp?p=345279#20
You can use the search box at the top of the page to find more to read about others with sticking panel doors.
Lucky is offline
Old 04-14-2014, 10:25 PM
my first pannel's Avatar
rear door popers
I pulled of the weather seals off and tweaked the pinch welds with a piece of 2x4 and a hammer and don't get crazy with it doesn't take much and they pop just rite and I also keep the hinges oiled up too
my first pannel is offline
Quick Reply: HHR panel rear door question
