supercharger install
Old 10-26-2014, 12:44 AM
RF2
RF2's Avatar
If you are in the middle of the parts gathering for your supercharger install and need bolts there is a place to go to. Its called BoltDepot.com they have just about every kind of bolt you will need.
I even found the hard to get shoulder bolts for the intake manifold. 8mm shoulder with a 6mm thread. They are a class 12.9 hardness
RF2 is offline
Old 10-26-2014, 09:04 AM
Good find !
Oldblue is online now
Old 10-26-2014, 06:57 PM
prod's Avatar
Have you tested them yet?
Looks to me like there may not be enough thread on there to get them all the way in. Is it a removable sheath you can cut to length or solid?
if so i may pick some up, I'm just using 6mm with washers.
prod is offline
Old 10-27-2014, 10:52 PM
RF2
RF2's Avatar
Picture is a little off. The threads are about 1 inch long. The Shoulder is solid, the bolt is one piece and they are hard. These are 3/8 of an inch longer than normal for the phenolic spacer I'm installing between the head and intake.
RF2 is offline
Old 10-28-2014, 12:01 AM
prod's Avatar
You have an automatic? Not sure I'd want an extra 3/8 on the front.
prod is offline
Old 10-28-2014, 12:13 AM
RF2
RF2's Avatar
Yes it's a auto. While it was in the shop getting fixed from the 1 ton episode. The whole radiator support has been moved with the bulkheads 1/2 forward to clear the supercharger pulley and give more wiggle room up front.
RF2 is offline
Old 10-28-2014, 03:36 AM
prod's Avatar
Good idea, thanks for the info.
prod is offline
Old 10-31-2014, 04:30 AM
TwistDaWrist's Avatar
I really want to zzp supercharge my hhr but i'm not 100% sure i have the motor i think i do my Vin is 3GNDA13DX7S505752 (its an 07) Can any of you inbox me and let me know what motor i have im thinking 2.2l but it could be any, help please?
TwistDaWrist is offline
Old 10-31-2014, 06:02 AM
prod's Avatar
Eighth digit in vin is the engine, D is 2.2, P would be 2.4
prod is offline
reno
2.4L Performance Tech
15
10-02-2013 08:49 PM
Drrick
16
09-15-2011 08:37 AM
Maroon06
81
04-30-2007 11:20 AM
sunburstchris
2.2L Performance Tech
01-09-2007 02:45 PM
Quick Reply: supercharger install
