New Owner, Couple of Questions
Old 03-15-2017, 04:50 PM
ACLR8R's Avatar
I searched but couldnt find anything. I bought my car this last weekend, and have been loving it, but it only run 6-7lbs in first gear then 22-23lbs in every other. Was this standard with a trifecta tune?
Also, has a small oil leak, anything they are known for?
Out of town until Saturday so havent been able to check it out.
ACLR8R is offline
Old 03-15-2017, 05:19 PM
celblazer's Avatar
If it's an auto it will run lower boost in 1st gear unless you asked them to tune it otherwise. I have an auto with full boost in all gears(Asked for it with the tune) but it makes first very interesting. LOL
celblazer is offline
Old 03-15-2017, 05:49 PM
ACLR8R's Avatar
Thanks, should have specified. 5spd
ACLR8R is offline
Old 03-15-2017, 08:05 PM
Oil leak , look at the oil pressure switch, above the starter motor.
Oldblue is offline
Old 03-15-2017, 08:48 PM
Give it a good degreasing, being careful around wiring connectors. Then you'll know if(or where) it's really leaking. Often it's just spills from refilling oil or changing the oil filter.
But don't just grab any engine cleaner, some are quite corrosive to aluminum.
RJ_RS_SS_350 is offline
Old 03-15-2017, 09:27 PM
Oil leak in what area of the engine ?
firemangeorge is online now
Old 03-16-2017, 08:54 AM
ACLR8R's Avatar
Any suggestions? I have used GUNK and STEAM with good results.
Touch to say right now, really dirty underhood, and just noticed that its dripping a couple of drips each day. Seems to be on the driverside, but it could be running off of something else.
ACLR8R is offline
Old 03-16-2017, 08:58 AM
Mine was the oil pressure switch, I use Gunk for degreasing!
Oldblue is offline
Old 03-16-2017, 10:26 AM
If you verify it is the oil pressure switch that is leaking, here is a how-to on replacing it: https://www.chevyhhr.net/forums/how-...ng-unit-57962/
whopper is offline
Old 03-16-2017, 11:04 AM
ACLR8R's Avatar
Thanks, Ill check it out this weekend when I get home!
ACLR8R is offline
Quick Reply: New Owner, Couple of Questions
