Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
#582
#584
wasn't paying attention to that little gray clip on the solenoid electrical connector. was praying it wouldn't break. didn't even know that it came out...lol. once i got them out, they snapped right on to the new ones. thought i had gottent he wrong part. wasted $54 getting a new one and they was the same part#. oh well, i have a spare now. but this thread helped out alot. plus i changed the air filter too. thanks for the post whooper and all that had positive input.
#586
Now i get a check engine light and car fumes from engine bay.
Excellent write up but what about the proper connections i think i hooked them up wrong and now i dont know which connector goes where?
#587
The connectors are unique for each solenoid - check the first posting - scroll down thru the pictures and you will see a picture of the solenoids still in place, with the connectors disconnected. Hopefully you got the solenoids installed correctly: ie: the intake on the intake side and the exhaust on the exhaust side?
#588
Hope this helps....
#590
