Rocker Panel removal
Old 02-09-2013, 11:54 AM
Radco's Avatar
Found this online
http://www.justanswer.com/chevy/3c1h...ng-boards.html
Open the doors on the side the molding is being removed from.
Remove the wheelhouse liner lower screw at each end of the rocker panel.
Rocker Panel Molding Locator Pin
Tip
Align the locator pin with the hole on body side outer panel when installing.
2 N·m (18 lb in)
Rocker Panel Molding Screw (Qty: 6)
Tighten
5 N·m (44 lb in)
Rocker Panel Molding Retainer Clip (Qty: 5)
Rocker Panel Molding Assembly
Radco is offline
Old 03-17-2013, 06:19 AM
Radco's Avatar
IMO Things wenat fairly easy for my as I picked up a cheap set of Door Panel/Trim removal tools off E Bay about 8$
Start by looking under the Rocker Panel and car.
You will see the clips..
4 on the bottom 8 on top
Remove the 10mm screw located in front of rear wheel,bottom panel side Save it! Watch out for the clip it screws into it may fall off!!!
Remove the 7mm screw in the front wheel well, bottom, panel side
watch out for the screw clip it also may fall off.
You can use the clips off the Rocker Panels if you lose any, my painter threw mine out
Start at the bottom, useing the V notch on the tool on each pin.. The tool will usually pinch the arms on the push pin and it will pop off, if not the break off still not a issue
Then tackle the top 8, using 2 or 3 tools to hold open the Panel while yanking on the bottom
I would have had pics but my camera crapped out
Hope I explained this well! Let me know if I didnt Thanks
Some trim tools
E bay
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Amazon
7 piece Nylon No-Scratch Pry Bars Automotive Trim Molding Removal Tools - Lifetime Warranty : Amazon.com : Automotive 7 piece Nylon No-Scratch Pry Bars Automotive Trim Molding Removal Tools - Lifetime Warranty : Amazon.com : Automotive
Radco is offline
Old 03-18-2013, 12:22 PM
Radco's Avatar
Let me know if this is enough info!
Originally Posted by Radco
Found this online
Tip
2 N·m (18 lb in)
Tighten
5 N·m (44 lb in)
Radco is offline
Finkle
04-23-2015 11:33 PM
kingkat4
Mods - Exterior
05-21-2011 07:23 AM
Jeff Wysocki
02-17-2009 09:27 PM
Quick Reply: Rocker Panel removal
