How-To edit your signature
Technical Moderator
This is a work in progress, be patient.
In the lower NavBar, Click "User CP".
"Your Control Panel" appears on the left.
Under "Settings & Options" click on "Edit Signature".
Enter the text you desire in the top edit box. You can modify the text using the edit tools in the tool bar.
Add pictures from your gallery.
Preview your new sig, if you like it save it.
There is more you can do. In any normal thread view or post view, lower left is a box labelled "Posting Rules". If that's all it says then click the chevron for the drop down. Click on "BB code" for a listing and tut on the use of the codes.
Premium Members can also edit/add an Avatar.
Technical Moderator
Or both. Plus I made a similar Unser comment in another thread recently.
It turns out the link was broken by one of the updates in the last 4 years anyway. Edited it out.
