Engine Rattle/shake
Old 03-21-2015, 10:04 AM
webpirate's Avatar
Engine Rattle/shake
Quick question for those more knowledgeable than me...
When I first start up my car in the morning, regardless of temperature, my 2007 HHR engine has a very tight shake...after a short drive it seems to be ok but everyone once in a while at a red light I can feel the engine rattle. If I let go of the brakes and move the car just an inch the rattle will go away..
could it be brake booster check valve?
webpirate is offline
Old 03-22-2015, 05:25 PM
Which engine do you have ?
Is it auto or standard?
It could be an engine mount gone soft or other issues
Is there a CEL light?
Oldblue is offline
Old 03-22-2015, 06:06 PM
black Tara's Avatar
I agree Engine mount.. If it is look into TTR motor mount. Great motor mount.
Or if it is the mount and you want to stay with Oem, I have one with 40,000 miles on it. I saved it after I put on the TTR motor mount. Make me an offer and it's yours!
Tim
black Tara is offline
Old 03-26-2015, 07:47 PM
webpirate's Avatar
its the 2.2L automatic transmission....
The engine shake/rattle is intermittent...Thats why I was thinking vaccum leak or maybe EGR valve..but no check engine lights...or dirty/loose spark plugs?
Old 03-26-2015, 07:55 PM
Technical Moderator
You have no EGR valve. Most vac leaks will throw a code, usually not seeming to be a vac leak.
donbrew is offline
Old 04-28-2015, 11:58 AM
webpirate's Avatar
Tim
$20+shipping?
prod
"How To" Tutorial Library
164
07-12-2018 08:20 PM
thomasamski
11-07-2014 11:36 PM
sking1973
04-13-2014 08:27 PM
Vcode455
06-25-2012 10:41 PM
Sneezy
08-10-2010 09:35 PM
Quick Reply: Engine Rattle/shake
