Loud humming noise.
Old 11-12-2010, 10:24 PM
Originally Posted by Zagohhr
Sleeper, I had the same issue as this (you posted on my thread). I changed the driver´s side hub bearing (mine had a humming noise and vibration when turn right). I did a test spinning the wheel on the passenger side... No noise... I changed many stuff on my hhr. Then, one day I removed the passenger side hub bearing and guess what? this was the cause!!! Now my hhr ride is smooth.
Zago-
Thanks for the feedback, I figured it could be felt...Guess not always..
sleeper is offline
Old 11-13-2010, 07:55 PM
Lake Runner's Avatar
I jacked it up and spun the tires. No noise. Passenger side turns a little easier than the driver's side. The more I hear it when I'm driving leads me to think the bearings are going out. I'll have to wait till I get some time from work to bring it in to the dealer. 5year/100k mile powertrain warranty, I hope this covers it.
Lake Runner is offline
Old 11-13-2010, 08:21 PM
Spozo's Avatar
Try jacking and spinning the wheels by hand again. While you're doing it, rest your other hand on the coil spring, lightly. If there is a wheel bearing gone, the side with the vibration will be the side with the defective bearing.
Spozo is offline
Old 11-15-2010, 01:55 AM
cc732's Avatar
Disc brake wear sensors near the edge of the front rotors "chirp" when the pads are nearly worn out. How the CV joints made out after the 5 foot "fall" is anyone's guess.
Clare
cc732 is offline
Old 12-02-2010, 11:57 AM
mrfcflash's Avatar
hub bearing
recently noiticed the same problem (65K miles)
just got a call fgorm the dealer today
definitely hub bearings
$850 repair from the dealer
mrfcflash is offline
Old 12-04-2010, 07:45 PM
Just got my '08 back from the dealer yesterday. Driver's side hub bearing was bad and replaced. I wish they would have replaced both sides, but I guess a return trip is in the future.
QbanBuc
06-28-2015 11:11 AM
Gregs
10-01-2013 04:04 PM
futureladycop227
07-17-2013 01:47 AM
DrummerHHR
07-11-2011 12:31 PM
mikeylikesit105
06-22-2011 08:58 AM
Quick Reply: Loud humming noise.
