Radio and Engine problem
I am a new member that bought my HHR in March. I had to get my windshield resealed in June and now I have two other problems. The first problem is the radio. After the car has been running for about 10-15 minutes "all" the radio buttons stop working. The other problem is a thud sound when starting the car. Has anyone else had these problems?
Originally Posted by snowfamily1
Sorry... I am new to the board. What does TSB stand for?
It's helpful to both YOU and the dealer by showing up with TSB's that fix known issues (as witnessed by others here on this forum) because a.) your problem should get fixed, and b.) the dealer doesn't have to waste a lot of time or "guess" as to what a fix may be.
TSB's are common with *ALL* vehicles!!! Just so happens to be a little more common with 1st model year releases (2006 HHR). Another thing... TSB's also help the manufacturer *fix* common problems AT THE FACTORY (during production) to avoid similar complaints from future owners down-the-road.
There is a list of all TSB's that have been located in one of the stickies above on this Problem/Service Issues board. One of our members dbarberaz has done a wonderful job gathering and updating the info for us.
Originally Posted by omega015
the thud or crack that you hear has been talked about on here before and there is a tsb to resolve the problem.
I even went to the NHSTA site and did a TSB search and didn't see anything directly relating to what snow is referring to. Only things I have seen is the clunk when turning...and snow states it's when starting.
Quick question for you snow...do you have CGS installed or have you tampered with or removed the big black box on top of the engine?
