clear coat peeling on wheels
Old 01-16-2011, 01:55 PM
DjLBM's Avatar
I have an 07 2LT. The clear coat is really starting to peel on my high polished 17" wheels. anyone else have this. I keep them clean and have never used any harsh cleaners. Just a soft towel when drying them. also my headliner is rattling around sunroof area.
DjLBM is offline
Old 01-16-2011, 02:02 PM
LawDog88's Avatar
I have the same rims I think, no problems here. Idk what to tell ya bud. As for the headliner, that IS covered under warranty as far as I know. I had mine fallin down and buggin me, and they took care of it no prob.
LawDog88 is offline
Old 01-16-2011, 02:08 PM
DjLBM's Avatar
It only has 51000 miles. I keep it clean. Spray it daily in these winter months. They have no curb rash or scuffs. peeling mainly on the spoked area. I don't get it. Thanks for the info on the headliner.
DjLBM is offline
Old 01-16-2011, 02:40 PM
LawDog88's Avatar
No problem man. My 08 is about to hit 40k and I told them about it, they jumped right on it. Being 6'2" you hear and notice ceiling things more than say a shorter person.
LawDog88 is offline
Old 01-16-2011, 02:51 PM
urbexHHR's Avatar
I remember my dad's Silverado's used to have this problem with it peeling on the wheels... We never figured out why...
urbexHHR is offline
Old 01-16-2011, 03:28 PM
weekendwarrior's Avatar
There is no definitive answer as to why clearcoat peels on wheels. You could have run through a puddle of water at some point, that had some contaminates - in other words, some harsh chemicals could have run into that puddle, then your drove through it.
Another scenario is that when your car was at a shop, brake cleaner or some other chemical could have gotten on the wheels, then the shop wiped it off, but some residue was left behind.
There are just way too many scenarios to tell you exactly what could have caused it. It could even be due to the process of finishing the wheels at the factory...maybe the prep machine or person was just having a bad day.
In terms of a solution, you either have to get a body shop to re clear them for you (assuming you cannot do it yourself)....or you use this as an opportunity to get new wheels!!!
weekendwarrior is offline
Old 01-16-2011, 03:48 PM
urbexHHR's Avatar
We had it peeling off the hubcaps on our G6, the service manager and tech kept arguing that it was from the carwash, even after we explained countless times how the car had never been through one. Thankfully the GM guy who looked at the car couldn't have cared less about it when we turned it in.
urbexHHR is offline
Old 01-16-2011, 06:19 PM
foolmoon_design's Avatar
Some places on the headliner are held up with double-sided sticky tape, sounds like this has let go and a clip is vibrating, or you have a broken pin tab on the sunroof(very common) that is jiggling in the track. if this is the case be careful opening the sunroof as you may have a problem closing it again. Because of this we always tilt ours and seldom open all the way.
foolmoon_design is offline
Old 01-16-2011, 07:06 PM
87silver's Avatar
Every GM vehicle that I've had as well as 2 I currently own with clearcoat wheels all eventally peel. I'm expecting my HHR SS to do the same after the warrantee is up (that's when it starts). It's just one of those imperfections with the build of these cars.
On the otherhand, my '87 Suzuki Samurai has Centerlines that I installed back in 1988. They don't have clearcoat and while not as shiny as day one, still don't have any nasty imperfections such as the peeling.
87silver is offline
Old 01-16-2011, 07:13 PM
bk94si's Avatar
yeah, I would rather they didn't clearcoat.
bk94si is offline
Quick Reply: clear coat peeling on wheels
