Racing Discussion Race Track Victories - DRIVE RESPONSIBLY
2nd gear burnout in the box
Old 09-16-2012, 12:50 PM
XtremeSS's Avatar
Read on css.net that in order to heat tires enough for drag strip, we need to do a 2nd gear burnout with e-brake engaged of course. Anyone ever done this with their HHR?
XtremeSS is offline
Old 09-16-2012, 01:02 PM
Bkm0607's Avatar
So with a auto do I just put ebreak up n floor it?
Bkm0607 is offline
Old 09-16-2012, 01:12 PM
RobSSTurbo's Avatar
I have done it you well have to keep the rpms high when you release the clutch but it's help so you not hitting the limiter during the burnout.
RobSSTurbo is offline
Old 09-16-2012, 04:59 PM
foolmoon_design's Avatar
Bkm, for the auto, turn traction off and snatch the e brake. If you leave traction on it will bog really quick. You may also find better overall times with traction off.
foolmoon_design is offline
Old 09-16-2012, 05:17 PM
Bkm0607's Avatar
So traction off or comp mode?
Bkm0607 is offline
Old 09-16-2012, 07:51 PM
RobSSTurbo's Avatar
Hit the traction botton and hold it for 10 seconds it well shut off the esc so it won't bog.
Old 09-16-2012, 07:59 PM
^this.
Old 09-16-2012, 08:02 PM
Bkm0607's Avatar
So hit turn off then hit n hold or press n hold??
Bkm0607 is offline
Old 09-16-2012, 08:10 PM
IgottaWoody's Avatar
push...hold...one time
IgottaWoody is offline
Old 09-16-2012, 08:16 PM
RobSSTurbo's Avatar
^this
Quick Reply: 2nd gear burnout in the box
