Oil Leak from Somewhere
Old 03-08-2013, 09:30 AM
oneboater's Avatar
Originally Posted by Dutch
I have this exact issue with my 2007 HHR LS and the funny thing is that the leak appears to originate from where the motor mount meets the frame. If there is not a hydraulic mount what else can it be? I checked everywhere around the engine and it is clean.
check your axle seals..common problem
oneboater is offline
Old 03-08-2013, 09:34 AM
oneboater's Avatar
Check your axle seals. I had one side leaking, looked like it wasnt seated all the way. Took a flat head screwdriver and hammer and lightly small increments tap the the metal part of seal inward and no more leaks. Becareful you could damage seal. For me was a quick fix. I called the dealer for axle seal replacement $150 bucks one side.
1970judge
08-14-2015 05:47 PM
gschroed
01-29-2014 07:24 AM
hurst2001
08-04-2013 04:45 PM
blomb
07-03-2008 11:30 AM
pobryne
06-05-2008 09:47 PM
Quick Reply: Oil Leak from Somewhere
