List of Diagnostic Trouble Codes for 2008-2010 HHR
Old 08-06-2008, 08:04 PM
mchuntley's Avatar
What exactly is a "B0019 Passenger Frontal Deployment Loop Stage 1"
And would I like Stage 2?
mchuntley is offline
Old 02-25-2009, 07:26 PM
urbexHHR's Avatar
Should a normal OBDII Scanner work on a 2006 HHR? I have one that I use on my 1999 Lumina, but it doesn't seem to connect to the HHR. It gives me an error message. Shouldn't this scanner work on the HHR too, or did they change something since my 1999?
urbexHHR is offline
Old 02-26-2009, 08:19 AM
Newer vehicles require a Tech II scanner and a CANDI module to pull codes and for programming. Your old scanner will not work with the new systems.
Old 02-26-2009, 08:24 AM
urbexHHR's Avatar
Ok...thanks! I was kinda worried that something was wrong on the HHR's end since it still worked in my car!
urbexHHR is offline
Old 08-22-2009, 07:21 PM
Wheatgerm's Avatar
Thanks Chevy MGR. The information is of great value. Know of any DRB 2's for sale cheap? Anything that will substitute for one as far as programming goes?
Wheatgerm is offline
Old 10-08-2009, 11:30 AM
2010 Diagnostic Trouble Codes
B & C Codes
DTC-DTC Descriptor
B0012-Driver Frontal Deployment Loop Stage 1--
B0013-Driver Frontal Deployment Loop Stage 2--
B0015-LF Pretensioner Deployment Loop--
B0016-Left Roof Rail Deployment Loop Stage 1--
B0019-Passenger Frontal Deployment Loop Stage 1--
B0020-Passenger Frontal Deployment Loop Stage 2--
B0022-RF Pretensioner Deployment Loop--
B0023-Right Roof Rail Deployment Loop Stage 1--
B0052-Deployment Commanded--
B0053-Deployment Commanded with Loop DTCs Present--
B0081-Passenger Presence System--
B0083-Electronic Front End Sensor 1--
B0085-LF Side Impact Sensor--
B0086-RF Side Impact Sensor--
B0090-Rollover Sensor--
B0158-Outside Air Temperature Sensor Circuit--
B0283-Electric Rear Defrost Circuit--
B0685-Security System Indicator Circuit--
B1000-Electronic Control Unit Performance--
B1001-Option Configuration Error--
B1004-Keep Alive Memory Reset--
B1009-EEPROM Checksum Mismatch--
B1011-System Disabled Information Stored Invalid Serial Data Received--
B1019-System Configuration Error--
B101D-ECU Hardware --
B101E-ECU Software --
B1025-Audio Output 1 Left Front Circuit--
B1035-Audio Output 2 Right Front Circuit --
B1045-Audio Output 3 Left Rear Circuit--
B1055-Audio Output 4 Right Rear Circuit--
B1259-Antenna Ground Circuit--
B1287-Amplifier Control Signal--
B1325-Device Power Circuit--
B1370-Device Ignition 1 Circuit--
B1380-Device Ignition ACCESSORY Circuit--
B1424-Device Voltage Low--
B1441-Device Ignition OFF, RUN, and CRANK Circuit--
B1516-Battery Current Sensor Performance--
B1517-Battery Voltage Plausibility Failure--
B2455-Cellular Phone Microphone Circuit Malfunction--
B2462-Global Positioning System Antenna Malfunction --
B2470-Cellular Phone Antenna Circuit Malfunction--
B2476-Cellular Phone Select Service Switch--
B2482-Cellular Phone Select Switch Range/Performance--
B2485-Wireless Communication Antenna Circuit --
B250D-Left Rear Door Unlatch Low Control Circuit--
B250E-Right Rear Door Unlatch Low Control Circuit--
B2530-Front Fog Lamps Control Circuit--
B2555-Passenger Compartment Lamp Control Circuit--
B2580-Headlamp High Beam Control Circuit--
B2645-Ambient Light Sensor Circuit--
B2705-Gearshift Unlock Circuit--
B2750-Horn Relay Coil Circuit--
B3006-Hood Ajar Circuit--
B3031-Security System Controller In Learn Mode--
B3055-No Transponder Modulation or No Transponder--
B3060-Unprogrammed Transponder Identification Code Received--
B3105-Keyless Entry System Key Fobs Not Programmed--
B3109-Keyless Transmitter 1 Low Battery--
B3110-Keyless Entry Transmitter 2 Low Battery--
B3111-Keyless Entry Transmitter 3 Low Battery--
B3112-Keyless Entry Transmitter 4 Battery--
B312A-Door Latch Actuators Enable Relay Control Circuit--
B3265-Hitch Release Output Circuit--
B3715-Front Wiper Relay Drive Circuit--
B3794-Cruise Control Function Request Circuit--
B3811-Rear Washer Relay Circuit --
B3903-Stop Lamp Relay Circuit--
B3935-Transponder Authentication Error--
B3948-Left Front Turn Signal Circuit--
B3949-Right Front Turn Signal Circuit--
B3950-Left Rear Turn Signal Circuit--
B3951-Right Rear Turn Signal Circuit--
B3976-Unconfigured Transponder/Vehicle Configuration Not Programmed--
C0000-Vehicle Speed Information Circuit--
C0035-Left Front Wheel Speed Sensor Circuit--
C0040-Right Front Wheel Speed Sensor Circuit--
C0045-Left Rear Wheel Speed Sensor Circuit--
C0050-Right Rear Wheel Speed Sensor Circuit--
C0110-Pump Motor Circuit--
C0131-ABS Pressure Circuit--
C0161-ABS/TCS Brake Switch Circuit--
C0176-System Thermal Error--
C0186-Lateral Accelerometer--
C0196-Yaw Rate Circuit--
C0201-Antilock Brake System Enable Relay Contact Circuit--
C0252-Steering Wheel Position Sensor--
C0267-Low Brake Fluid Indicated--
C0277-Brake Pedal Position Sensor Circuit--
C0278-Brake Pedal Position Sensor--
C0280-Stability System Active Too Long--
C0292-VSES Combination Sensor Circuits--
C0299-Brake Booster Performance--
C0460-Steering Position Signal--
-Steering Position Sensor --
C0475-Electric Steering Motor Circuit--
C0545-Steering Wheel Torque Input Sensor--
C0550-Electronic Control Unit Performance--
C0551-Option Configuration Error--
C0561-System Disabled Information Stored--
C0569-System Configuration Error--
C056D-Electronic Control Unit Hardware --
-ECU Hardware Performance--
C056E-Electronic Control Unit Software --
-ECU Software Performance--
C0750-Left Front Low Tire Pressure Sensor--
C0755-Right Front Low Tire Pressure Sensor--
C0760-Left Rear Low Tire Pressure Sensor--
C0765-Right Rear Low Tire Pressure Sensor--
C0775-Low Tire Pressure System Sensors Not Learned--
C0800-Device Power Circuit Voltage--
C0845-Device Ignition 1 Circuit--
C0870-Device Voltage Reference Output 1 Circuit Voltage--
C0895-Device Voltage --
C0899-Device Voltage Low --
C0900-Device Voltage High --
C1100-Brake Booster Vacuum Sensor--
Old 10-08-2009, 11:32 AM
2010
P Codes
P000A-Intake Camshaft Position System Slow Response --
P000B-Exhaust Camshaft Position System Slow Response --
P0010-Intake Camshaft Position Actuator Solenoid Control Circuit--
P0011-Intake Camshaft Position System Performance--
P0013-Exhaust Camshaft Position Actuator Solenoid Control Circuit--
P0014-Exhaust Camshaft Position System Performance--
P0016-Crankshaft Position Intake-Camshaft Position Correlation-
P0017-Crankshaft Position -Exhaust Camshaft Position Correlation-
P0030-HO2S Heater Control Circuit Sensor 1--
P0031-HO2S Heater Control Circuit Low Voltage Sensor 1--
P0032-HO2S Heater Control Circuit High Voltage Sensor 1--
P0033-Turbocharger Bypass Valve Solenoid Control Circuit--
P0034-Turbocharger Bypass Valve Solenoid Control Circuit Low Voltage--
P0035-Turbocharger Bypass Valve Solenoid Control Circuit High Voltage--
P0036-HO2S Heater Control Circuit Sensor 2--
P0037-HO2S Heater Control Circuit Low Voltage Sensor 2--
P0038-HO2S Heater Control Circuit High Voltage Sensor 2--
P0053-HO2S Heater Resistance Sensor 1--
P0054-HO2S Heater Resistance Sensor 2--
P0068-Throttle Body Airflow Performance--
P0087-Fuel Rail Low Pressure--
P0088-Fuel Rail High Pressure--
P0089-Fuel Pressure Regulator Performance--
P0090-Fuel Pressure Regulator 1 Control Circuit--
P0091-Fuel Pressure Regulator Solenoid 1 Control Circuit Low Voltage--
P0092-Fuel Pressure Regulator Solenoid 1 Control Circuit High Voltage--
P0096-Intake Air Temperature Sensor 2 Performance--
P0097-Intake Air Temperature Sensor 2 Circuit Low Voltage--
P0098-Intake Air Temperature Sensor 2 Circuit High Voltage--
P0099-Intake Air Temperature Sensor 2 Circuit Intermittent--
P0100-Mass Air Flow Sensor Circuit--
P0101-Mass Air Flow Sensor Performance--
P0102-Mass Air Flow Sensor Circuit Low Frequency--
P0103-Mass Air Flow Sensor Circuit High Frequency--
P0106-Manifold Absolute Pressure Sensor Performance--
P0107-Manifold Absolute Pressure Sensor Circuit Low Voltage--
P0108-Manifold Absolute Pressure Sensor Circuit High Voltage--
P0112-Intake Air Temperature Sensor Circuit Low Voltage--
P0113-Intake Air Temperature Sensor Circuit High Voltage--
P0114-Intake Air Temperature Sensor Circuit Intermittent--
P0116-Engine Coolant Temperature Sensor Performance--
P0117-Engine Coolant Temperature Sensor Circuit Low Voltage--
P0118-Engine Coolant Temperature Sensor Circuit High Voltage--
P0119-Engine Coolant Temperature Sensor Circuit Intermittent--
P0120-Throttle Position Sensor 1 Circuit--
P0121-Throttle Position Sensor 1 Performance--
P0122-Throttle Position Sensor 1 Circuit Low Voltage--
P0123-Throttle Position Sensor 1 Circuit High Voltage--
P0128-Engine Coolant Temperature Below Thermostat Regulating Temperature--
P0130-HO2S Circuit Closed Loop Performance Sensor 1--
P0131-HO2S Circuit Low Voltage Sensor 1--
P0132-HO2S Circuit High Voltage Sensor 1--
P0133-HO2S Slow Response Sensor 1--
P0134-HO2S Circuit Insufficient Activity Sensor 1--
P0135-HO2S Heater Performance Sensor 1--
P0137-HO2S Circuit Low Voltage Sensor 2--
P0138-HO2S Circuit High Voltage Sensor 2--
P013A-HO2S Slow Response Rich to Lean Sensor 2--
P013B-HO2S Slow Response Lean to Rich Sensor 2--
P013E-HO2S Delayed Response Rich to Lean Sensor 2--
P013F-HO2S Delayed Response Lean to Rich Sensor 2--
P0140-HO2S Circuit Insufficient Activity Sensor 2--
P0141-HO2S Heater Performance Sensor 2--
P0171-Fuel Trim System Lean--
P0172-Fuel Trim System Rich--
P0191-Fuel Rail Pressure Sensor Performance--
P0192-Fuel Rail Pressure Sensor Circuit Low Voltage--
P0193-Fuel Rail Pressure Sensor Circuit High Voltage--
P0201-Cylinder 1 Injector Control Circuit--
P0202-Cylinder 2 Injector Control Circuit--
P0203-Cylinder 3 Injector Control Circuit--
P0204-Cylinder 4 Injector Control Circuit--
P0218-Transmission Fluid Overtemperature--
P0219-Engine Overspeed Condition --
P0220-Throttle Position Sensor 2 Circuit--
P0221-Throttle Position Sensor 2 Performance--
P0222-Throttle Position Sensor 2 Circuit Low Voltage--
P0223-Throttle Position Sensor 2 Circuit High Voltage--
P0230-Fuel Pump Relay Control Circuit--
P0234-Turbocharger Engine Overboost--
P0236-Turbocharger Boost System Performance--
P0237-Turbocharger Boost Sensor Circuit Low Voltage--
P0238-Turbocharger Boost Sensor Circuit High Voltage--
P0243-Turbocharger Wastegate Solenoid Control Circuit--
P0245-Turbocharger Wastegate Solenoid Control Circuit Low Voltage--
P0246-Turbocharger Wastegate Solenoid Control Circuit High Voltage--
P0261-Cylinder 1 Injector Control Circuit Low Voltage--
P0262-Cylinder 1 Injector Control Circuit High Voltage--
P0264-Cylinder 2 Injector Control Circuit Low Voltage--
P0265-Cylinder 2 Injector Control Circuit High Voltage--
P0267-Cylinder 3 Injector Control Circuit Low Voltage--
P0268-Cylinder 3 Injector Control Circuit High Voltage--
P0270-Cylinder 4 Injector Control Circuit Low Voltage--
P0271-Cylinder 4 Injector Control Circuit High Voltage--
P0299-Turbocharger Engine Underboost--
P029D-Cylinder 1 Injector Leak Detected--
P02A1-Cylinder 2 Injector Leak Detected--
P02A5-Cylinder 3 Injector Leak Detected--
P02A9-Cylinder 4 Injector Leak Detected--
P0300-Engine Misfire Detected--
P0301-Cylinder 1 Misfire Detected--
P0302-Cylinder 2 Misfire Detected--
P0303-Cylinder 3 Misfire Detected--
P0304-Cylinder 4 Misfire Detected--
P0315-Crankshaft Position System Variation Not Learned--
P0324-Knock Sensor Performance--
P0325-Knock Sensor Circuit--
P0326-Knock Sensor 1 Performance--
P0327-Knock Sensor 1 Circuit Low Voltage--
-Knock Sensor Circuit Low Voltage--
P0328-Knock Sensor 1 Circuit High Voltage--
-Knock Sensor Circuit High Voltage--
P0331-Knock Sensor 2 Performance--
P0332-Knock Sensor 2 Circuit Low Voltage--
P0333-Knock Sensor 2 Circuit High Voltage--
P0335-Crankshaft Position Sensor Circuit--
P0336-Crankshaft Position Sensor Performance--
P0338-Crankshaft Position Sensor Circuit High Duty Cycle--
P0340-Intake Camshaft Position Sensor Circuit--
P0341-Intake Camshaft Position Sensor Performance--
P0342-Intake Camshaft Position Sensor Circuit Low Voltage--
P0343-Intake Camshaft Position Sensor Circuit High Voltage--
P0351-Ignition Coil 1 Control Circuit--
P0352-Ignition Coil 2 Control Circuit--
P0353-Ignition Coil 3 Control Circuit--
P0354-Ignition Coil 4 Control Circuit--
P0365-Exhaust Camshaft Position Sensor Circuit--
P0366-Exhaust Camshaft Position Sensor Performance--
P0367-Exhaust Camshaft Position Sensor Circuit Low Voltage--
P0368-Exhaust Camshaft Position Sensor Circuit High Voltage--
P0420-Catalyst System Low Efficiency--
P0442-Evaporative Emissions System Small Leak Detected--
P0443-Evaporative Emission Purge Solenoid Control Circuit--
P0446-Evaporative Emissions Vent System Performance--
P0449-Evaporative Emission Vent Solenoid Control Circuit--
P0450-Fuel Tank Pressure Sensor Circuit--
P0451-Fuel Tank Pressure Sensor Performance--
P0452-Fuel Tank Pressure Sensor Circuit Low Voltage--
P0453-Fuel Tank Pressure Sensor Circuit High Voltage--
P0454-Fuel Tank Pressure Sensor Circuit Intermittent--
P0455-Evaporative Emission System Large Leak--
P0458-Evaporative Emission Purge Solenoid Control Circuit Low Voltage--
P0459-Evaporative Emission Purge Solenoid Control Circuit High Voltage--
P0461-Fuel Level Sensor Circuit Performance--
P0462-Fuel Level Sensor Circuit Low Voltage--
P0463-Fuel Level Sensor Circuit High Voltage--
P0464-Fuel Level Sensor 1 Circuit Intermittent--
P0480-Cooling Fan Speed Output Circuit--
-Cooling Fan Relay Control Circuit--
P0496-Evaporative Emission System Flow During Non-Purge-
P0497-Evaporative Emission System Low Purge Flow--
P0498-Evaporative Emission Vent Solenoid Control Circuit Low Voltage--
P0499-Evaporative Emission Vent Solenoid Control Circuit High Voltage--
P0501-Vehicle Speed Sensor Performance--
P0502-Vehicle Speed Sensor Circuit Low Voltage--
P0503-Vehicle Speed Sensor Circuit Intermittent--
P0506-Idle Speed Low--
P0507-Idle Speed High--
P050A-Cold Start Idle Air Control System Performance--
P0520-Engine Oil Pressure Sensor Circuit--
P0532-Air Conditioning Refrigerant Pressure Sensor Circuit Low Voltage--
P0533-Air Conditioning Refrigerant Pressure Sensor Circuit High Voltage--
P0556-Brake Booster Pressure Sensor Performance --
P0557-Brake Booster Pressure Sensor Circuit Low Voltage --
P0558-Brake Booster Pressure Sensor Circuit High Voltage --
P0562-System Voltage Low--
P0563-System Voltage High--
P0571-Cruise Control Brake Switch Circuit --
P0572-Brake Switch Circuit 1 Low Voltage--
P0573-Brake Switch Circuit 1 High Voltage--
P0575-Cruise Control Switch Signal Circuit--
Old 10-08-2009, 11:34 AM
2010
P Codes Continued
P0601-Control Module Read Only Memory--
-Control Module Read Only Memory Performance--
-Transmission Control Module Read Only Memory--
P0602-Control Module Not Programmed--
-Transmission Control Module Not Programmed--
P0603-Control Module Long Term Memory Reset--
-Transmission Control Module Long Term Memory Reset--
P0604-Control Module Random Access Memory--
-Control Module Random Access Memory Performance--
-Transmission Control Module Random Access Memory--
P0606-Control Module Internal Performance--
-Control Module Processor Performance--
P0607-Control Module Performance--
P060D-Control Module Accelerator Pedal Position System Circuitry Performance--
P0615-Starter Relay Control Circuit--
P0616-Starter Relay Control Circuit Low Voltage --
P0617-Starter Relay Control Circuit High Voltage --
P0621-Generator L-Terminal Circuit-
P0622-Generator F-Terminal Circuit-
P0627-Fuel Pump Relay Control Circuit--
P0628-Fuel Pump Relay Control Circuit Low Voltage--
P0629-Fuel Pump Relay Control Circuit High Voltage--
P062B-Control Module Fuel Injector Control Performance--
P062F-Control Module Long Term Memory Performance--
-Transmission Control Module Long Term Memory Performance--
P0638-Throttle Actuator Control Command Performance--
P0641-5 V Reference 1 Circuit--
P0642-5 V Reference 1 Low Voltage--
P0643-5 V Reference 1 High Voltage--
P0645-Air Conditioning Clutch Relay Control Circuit--
P064D-Control Module HO2S 1 System Performance--
P0650-Malfunction Indicator Lamp Control Circuit--
P0651-5 V Reference 2 Circuit--
P0652-5 V Reference 2 Low Voltage--
P0653-5 V Reference 2 High Voltage--
P0685-Engine Controls Ignition Relay Control Circuit--
P0686-Engine Controls Ignition Relay Control Circuit Low Voltage--
P0687-Engine Controls Ignition Relay Control Circuit High Voltage--
P0689-Engine Controls Ignition Relay Feedback Circuit Low Voltage--
P0690-Engine Controls Ignition Relay Feedback Circuit High Voltage--
P0691-Cooling Fan Speed Output Circuit Low Voltage--
P0692-Cooling Fan Speed Output Circuit High Voltage--
P0697-5 V Reference 3 Circuit--
P0698-5 V Reference 3 Low Voltage--
P0699-5 V Reference 3 High Voltage--
P0700-Transmission Control Module Requested MIL Illumination--
P0703-Brake Switch Circuit 2--
P0705-Transmission Range Switch Circuit--
P0711-Transmission Fluid Temperature Sensor Performance--
P0712-Transmission Fluid Temperature Sensor Circuit Low Voltage--
P0713-Transmission Fluid Temperature Sensor Circuit High Voltage--
P0716-Input Speed Sensor Performance--
P0717-Input Speed Sensor Circuit Low Voltage--
P0722-Output Speed Sensor Circuit Low Voltage--
P0723-Output Speed Sensor Circuit Intermittent--
P0741-Torque Converter Clutch System - Stuck Off-
P0742-Torque Converter Clutch System - Stuck On-
P0751-1-2 Shift solenoid Valve Performance - No First or Fourth Gear
P0752-1-2 Shift solenoid Valve Performance - No Second or Third Gear
P0756-2-3 Shift Solenoid Valve Performance - No First or Second Gear
P0757-2-3 Shift Solenoid Valve Performance - No Third or Fourth Gear
P0806-Clutch Pedal Position Sensor Circuit Performance--
P0807-Clutch Pedal Position Sensor Circuit Low Voltage--
P0808-Clutch Pedal Position Sensor Circuit High Voltage--
P080A-Clutch Pedal Position Not Learned--
P0842-Transmission Fluid Pressure Sensor Circuit Low Voltage--
P0843-Transmission Fluid Pressure Sensor Circuit High Voltage--
P0856-Engine Control Module Traction Control Torque Request Circuit--
P0961-Line Pressure Control Solenoid System Performance--
P0973-1-2 Shift Solenoid Control Circuit Low Voltage-
P0974-1-2 Shift Solenoid Control Circuit High Voltage-
P0976-2-3 Shift Solenoid Control Circuit Low Voltage-
P0977-2-3 Shift Solenoid Control Circuit High Voltage-
P1101-Intake Air Flow System Performance--
P1133-HO2S Insufficient Switching Sensor 1--
P1174-Fuel Trim Cylinder Balance--
P1400-Cold Start Emission Reduction Control System--
P150C-Transmission Control Module Engine Speed Request Circuit --
P1516-Throttle Actuator Control Module Throttle Actuator Position Performance--
P1551-Throttle Valve Rest Position Not Reached During Learn--
P1630-Theft Deterrent Learn Mode Active--
P1631-Theft Deterrent Fuel Enable Signal Not Correct--
P1632-Theft Deterrent Fuel Disable Signal Received--
P167D-Control Module Ignition Coil Internal Circuit--
P1682-Ignition 1 Switch Circuit 2--
P1810-Transmission Fluid Pressure Position Switch Circuit --
P1811-Maximum Adapt and Long Shift--
P1816-Transmission Fluid Pressure Valve Position Switch Indicates Park/Neutral with Drive Ratio --
P1818-Transmission Fluid Pressure Valve Position Switch Indicates Drive without Drive Ratio --
P2088-Intake Camshaft Position Actuator Solenoid Control Circuit Low Voltage--
P2089-Intake Camshaft Position Actuator Solenoid Control Circuit High Voltage--
P2090-Exhaust Camshaft Position Actuator Solenoid Control Circuit Low Voltage--
P2091-Exhaust Camshaft Position Actuator Solenoid Control Circuit High Voltage--
P2096-Post Catalyst Fuel Trim System Low Limit Bank 1--
P2097-Post Catalyst Fuel Trim System High Limit Bank 1--
P2100-Throttle Actuator Control Motor Control Circuit--
P2101-Throttle Actuator Position Performance--
P2105-Throttle Actuator Control System Forced Engine Shutdown--
P2119-Throttle Closed Position Performance--
P2120-Accelerator Pedal Position Sensor 1 Circuit--
P2122-Accelerator Pedal Position Sensor 1 Circuit Low Voltage--
P2123-Accelerator Pedal Position Sensor 1 Circuit High Voltage--
P2125-Accelerator Pedal Position Sensor 2 Circuit--
P2127-Accelerator Pedal Position Sensor 2 Circuit Low Voltage--
P2128-Accelerator Pedal Position Sensor 2 Circuit High Voltage--
P2135-Throttle Position Sensor 1-2 Correlation-
P2138-Accelerator Pedal Position Sensor 1-2 Correlation-
P2146-Cylinder 1 Injector High Control Circuit--
P2149-Cylinder 2 Injector High Control Circuit--
P2152-Cylinder 3 Injector High Control Circuit--
P2155-Cylinder 4 Injector High Control Circuit--
P2176-Minimum Throttle Position Not Learned--
P2177-Fuel Trim System Lean at Cruise or Accel--
P2178-Fuel Trim System Rich at Cruise or Accel--
P2187-Fuel Trim System Lean at Idle--
P2188-Fuel Trim System Rich at Idle--
P2195-HO2S Signal Biased Lean Sensor 1--
P2196-HO2S Signal Biased Rich Sensor 1--
P2199-Intake Air Temperature Sensor 1-2 Correlation-
P2227-Barometric Pressure Sensor Performance--
P2228-Barometric Pressure Sensor Circuit Low Voltage--
P2229-Barometric Pressure Sensor Circuit High Voltage--
P2232-HO2S Signal Circuit Shorted to Heater Circuit Sensor 2--
P2237-HO2S Pumping Current Control Circuit Sensor 1--
P2238-HO2S Pump Current Control Circuit Low Voltage Sensor 1 --
P2239-HO2S Pump Current Control Circuit High Voltage Sensor 1 --
P2243-HO2S Reference Voltage Circuit Sensor 1--
P2251-HO2S Low Reference Circuit Sensor 1--
P2261-Turbocharger Bypass Valve Stuck Closed--
P2270-HO2S Signal Stuck Lean Sensor 2--
P2271-HO2S Signal Stuck Rich Sensor 2--
P2297-HO2S Performance During Decel Fuel Cut-Off Sensor 1-
P2500-Generator L-Terminal Circuit Low -
P2501-Generator L-Terminal Circuit High -
P2534-Ignition 1 Switch Circuit Low Voltage--
P2544-Transmission Torque Request Circuit--
P258A-Vacuum Pump Relay Control Circuit--
P258B-Vacuum Pump Performance--
P258C-Vacuum Pump Relay Control Circuit Low Voltage--
P258D-Vacuum Pump Relay Control Circuit High Voltage--
P2610-Control Module Ignition Off Timer Performance--
P2626-HO2S Pumping Current Trim Circuit Sensor 1--
P2763-Torque Converter Clutch Pressure Control Solenoid Control Circuit High Voltage--
P2764-Torque Converter Clutch Pressure Control Solenoid Control Circuit Low Voltage--
P2A00-HO2S Circuit Closed Loop Performance Sensor 1--
2010
U Codes
U0001-High Speed Controller Area Network Communication Bus--
U0073-Controller Area Network Bus Communication--
U0100-U0299-Lost Communication With XXX Control Module-
U2103-Fewer Controllers On Bus Than Programmed--
U2105-U2199-Lost Communication With XXX Control Module-
023-Seat Belt Tension Sensor Circuit Out of Range--
024-Passenger Presence System Ignition 1 Voltage Performance--
063-Passenger Presence System Out of Calibration--
064-Communication/ID Performance--
065-Sensor Circuit Out of Range--
1066-Battery Voltage Low --
1067-Battery Voltage High --
1068-Battery Voltage Out Of Range--
1071-Passenger Presence System 1 Calibration Not Learned --
1072-Passenger Presence System 1 Plausibility Failure --
2001 - 2054-Internal Electronic Performance 1 -
202A-202E -Internal Electronic Performance 1 -
3003-3059 -Passenger Occupant Classification Sensor Circuit -
300A-Passenger Occupant Classification Sensor Circuit --
301A-Passenger Occupant Classification Sensor Circuit --
303A-303E -Passenger Occupant Classification Sensor Circuit -
305A-305C-Passenger Occupant Classification Sensor Circuit -
4061-4065-Loss Of Class 2 Communication -
Old 10-08-2009, 10:22 PM
IgottaWoody's Avatar
Remember the good old days when ALL the codes could be listed on a single page.........
IgottaWoody is offline
Quick Reply: List of Diagnostic Trouble Codes for 2008-2010 HHR
