knocking noise
Old 01-30-2010, 05:19 PM
ginginee's Avatar
knocking noise
Hey, I have been hearing a "knocking" (tapping) noise that seems to be coming from the left front tire area. Or at least that seems to be the area. When I idle no noise. As I drive I hear it and the faster I go the faster the knocking is. I took it to my mechanic and he has no clue! He put it on the hoist and rotated the tires....still knocking. He has no idea what it is and told me to drive it for a "week or three" and if it gets worse let him know. Does anyone have any idea what this could be? The mechanic doesn't think it's the wheel bearing, not sure if he even checked it. I have a 2006 HHR. If anyone could come up with something plz let me know. We are going to take it to the chevy dealer next week.
ginginee is offline
Old 01-30-2010, 08:14 PM
Scrivs's Avatar
My knock occurred when I hit a bump in the road...not on smooth surfaces. Turned out to be a stablizier link.
Scrivs is offline
Old 01-30-2010, 10:15 PM
ginginee's Avatar
This knock is always when the wheel is turning even on smooth roads.
ginginee is offline
Old 01-31-2010, 03:15 AM
TiggersHHR's Avatar
I would suggest having your mechanic inspect the CV Joint on the Axle Shaft closest to the wheel. You might have a torn or ripped CV Boot, which could have allowed road debris and moisture in. The CV Joint may be going back, especially if it is always knocking when you are turning.
TiggersHHR is offline
Old 01-31-2010, 08:16 AM
Scrivs's Avatar
DITTO-Especially if only when turning. Only other thing you can do is see if your front tire is rubbing when cranking the wheel either direction
Scrivs is offline
Old 01-31-2010, 08:20 AM
I may be wrong but I think you guys may be misinterpreting what the OP means. In this case when they say when the wheel is turning I think they mean when the wheel is rotating.
Not knowing what kind of tapping/knocking this noise is makes me wonder if something could be stuck in the tire.
HillsdaleHHR is offline
Old 01-31-2010, 10:56 AM
ginginee's Avatar
It can't be in the tire as he rotated the tires for me and the "knocking" continues. It's constant noise while I am driving....going straight or turning.
ginginee is offline
Old 01-31-2010, 11:11 AM
bunkie's Avatar
Does the noise increase or decrease with the speed of the car? I'm sorry I see now that it is speed sensitive-has to be CV or wheel hub related.
bunkie is offline
Old 01-31-2010, 11:40 AM
ginginee's Avatar
Thank you all. I'll have the mechanic check the CV
ginginee is offline
Old 01-31-2010, 12:43 PM
CarlsSS's Avatar
Sounds like a hub bearing let go... Mine went out at a little over 30K and it was covered under warranty.
CarlsSS is offline
Quick Reply: knocking noise
