Front Door Speaker Replacement
Old 07-27-2013, 04:47 PM
jimpennjr's Avatar
The same three are out on mine too. Just bought replacements today. Hoping to install today or tomorrow.
Originally Posted by fastsuv
Yes it's possible 3 speakers went bad. That's exactly what happened to me, except the remaining speaker that was still good was the right front.
Steve
jimpennjr is offline
Old 11-09-2013, 04:36 PM
Cael's Avatar
Originally Posted by prod
Ok, heres a few showing what the factory speaker setup is like. The problem is the hole in the door is not round, more of a teardrop shape. Also they are raised from the surface to seal against the interior panel. My solution was to make my own rings from MDF wood, but plastic adapters are available, try searching for them on ebay.
Hi. wich size are this HHR speakers? 5 1/4 or 6 1/2?
Thanks.
Cael is offline
Old 11-09-2013, 04:48 PM
read the first post in this thread.
Old 03-31-2018, 07:13 AM
kamikaze3557's Avatar
Been reading thru the threads that are "speaker / stereo" related, thought not to post new topic and ask here...
I have an HHR with Base stereo and speakers and looking to replace....I'm handy enough to do the job myself
and here is what I have read here so far.
Base model (non Pioneer?)
Front speakers 6.5 @ 4 Ohm
Rear speaker 6.5 @ 8 ohm
(no Sub)
Now unless I've missed something or haven't researched deeply enough, does anyone know the power handing
in watts of the front and rears?
Most aftermarket I've looked at on the lower end speakers are about 30w each 60w rms per pair.
Now I went to chruchfeld and told them I was looking for 6.5 " 60w pair but 8 ohms speaker for the rear sense that is what I've read
is the original specs, they sent me a link to some high priced speakers that did not fit these specs. But may have been ones that fit the
upgraded Pioneer system. Which I do not have. I'm just looking for some lower end speaker .
have ordered front speakers that I hope will do OK.
  • Kenwood 6-1/2" 2-Way Sport Series Flush Mount Car Speaker System
  • 1" balanced dome tweeter
  • Ohm impedance: 4
  • Power Output:
    • Peak: 300 Watts/ per pair (150 Watts each)
    • RMS: 60 Watts/ per pair (30 Watts each
Now I'm looking for some 8 ohm, 6.5" 60w pair for the rear.
If I have any of this info incorrect and or going in the wrong direction for the rears
please feel free to advise, once again I'm going lower end speaker about the $50 pair range.
I just want something in there that I can can get by with.
Thanks,
Mike
kamikaze3557 is offline
Old 03-31-2018, 08:57 AM
Why not saunter into your local Walmart and pick a pair of 6.5 speakers. Since you are tal;king low end there is no reason to agonize over specs.
Doesn't Crutchfield have a search option by vehicle? Yes, they do: https://www.crutchfield.com/g_473750....html?tp=78072
Old 03-31-2018, 11:10 AM
Donbrew, thanks for the reply
I did that first and my local Wally World didn't have the ones they said they had in stock online at my local WM....That is what I'll probably do when it comes time to replace the rear door speakers and when they get restocked....
Tho I will keep searching for the 8 ohm speakers to match original specs.....I see a lot of 4 ohm.....as with my guitar amps I match my speakers to the amp requirements.
Old 04-02-2018, 07:57 PM
A nice deal for 4 Kickers
https://www.ebay.com/itm/2-Pairs-Kic...2610082?_ul=CA
Old 04-02-2018, 08:13 PM
That is a damn good deal, now I wish I hadn't ordered those 2 kenwoods, ..still confused about the 4 ohm fronts and 8 ohm rears on the basic stereo package, and if that could hurt the amp in the stereo....
Old 04-02-2018, 08:17 PM
Might sound a little off but , not to disturbing.
Old 04-02-2018, 08:27 PM
I play a little guitar and write songs so it should sound fine...my ears are use to things sounding a little off, but not to disturbing....smile
Quick Reply: Front Door Speaker Replacement
