Rear wiper removal mod??
Old 05-29-2008, 09:51 PM
JACK-07's Avatar
I see that So Cal peeps are holding a clinic.. but i live all the way in Florida.
Anyone remove the rear wiper?
Did you take pics?
that would be the best...
JACK-07 is offline
Old 05-29-2008, 10:19 PM
HipHotRod's Avatar
Jack, here's a play by play
Step by step:
Remove cap from wiper arm.
Remove bolt holding on wiper arm.
Remove wiper arm by pulling firmly and rocking lightly.
Remove rubber motor grommet from wiper motor
Remove two plastic rivets at bottom on door panel by pushing center
of rivet in 1/16th" and then remove entire rivet.
Pulling downward on the rear hatch handle along the top edge of it
will release the top of the handle from the hatch and you can remove it too.
Remove the third brake light cover by pulling it straight off. If you start at one side and pull up the end as it lays on the lower hatch panel and pull straight out. Then work your way across being careful not to twist it.
Remove the lower hatch panel starting at the top edge and working your way down. You are pulling plastic fasteners that can be strong. Just pull downward until they let go working your way around the panel. It is helpful to have an extra set of hands at this point to avoid dropping your interior panel.
If any of the fasteners remain in the hatch after removing the cover they must be carefully removed from the hatch and placed back in their slots on the hatch panel before re-installing the cover.
Remove the electrical connector from the wiper motor. Black tape the connector and wrap it toether on the existing harness so it won't rattle.
Remove the 3 - 10mm bolts holding the wiper motor in place then carefully pull it down and off of the rear hatch.
Install the plug of choice in wiper hole.
Carefully reinstall lower hatch panel being careful to line up guide pins and plastic fasteners with the correct holes. Have someone hold the hatch slightly closed so you don't hurt the hinges and pop the panel on by upward blows from hands until it seated flush with the hatch.
Reinstall the third brake light cover,
Pull center of the rivets out so when you place them back in their hole you just push in the center to lock them in place.
Reinstall the hatch handle...
HipHotRod is offline
Old 05-29-2008, 10:48 PM
c2vette's Avatar
Just a couple of points to add (possibly obvious). When removing the 3 bolts that hold the wiper motor, make sure you keep a good grip on it so as not to drop it on the bumper.
Don't forget to zip-tie the electrical connector so it doesn't rattle.
When re-installing the plastic, take extra care to ensure all retainers are lined up with their respective mounting holes, it is very easy to damage the panel if they are not lined up precisely when you pound it back in place.
I got a clean look by using a plastic body panel retainer (and the stock grommet) pushed into a fender washer on the inside to plug the hole. Doesn't hurt to add silicone grease to ensure a water tight seal.
c2vette is offline
Old 05-29-2008, 10:56 PM
afs9's Avatar
If you go down to I think #47, you can see a pic Kim's SOM without the wiper.
https://www.chevyhhr.net/forums/show...t=15323&page=2
And other pix of my my blackie, & don's white HHR
afs9 is offline
Old 05-30-2008, 08:22 AM
So.......what is everyone doing w/ the sprayer at the top?
jx3 is offline
Old 05-30-2008, 09:16 AM
Big Kahuna's Avatar
How about re-routing the nozzle to spray on tailgaters...
Big Kahuna is offline
Old 05-30-2008, 09:41 AM
HipHotRod's Avatar
Thats what Im doin Kahuna!. I ordered a 500GPH washer pump upgrade and fillin the tank with black ink
Old 05-30-2008, 10:24 AM
TkHHR's Avatar
I am considering using the washer hole to install this stylish back up camera now available for nuclear power plants and HHRs.
TkHHR is offline
Old 05-30-2008, 10:56 AM
afs9's Avatar
Dang you both!
I just spit out my coffee all over my desk!
Needed a good laugh this morning!
afs9 is offline
Old 06-01-2008, 10:45 PM
Ratzilla's Avatar
umm uhh, scary thing is, I believe him
curtsy
E'
Ratzilla is offline
Quick Reply: Rear wiper removal mod??
