Rear hatch won't latch
Old Nov 1, 2008 | 01:36 PM
Seca650RJ's Avatar
I believe i have a variation of the problem with the rear hatch locking and not opening. But in my case, it was open and now will not latch. I have checked fuses, searched through stuff here but came up with the rear lock problem as the only solution that comes close. So is there anything i am overlooking or does the car need to go to the dealer for the recall on the hatch? Car is a 2006 LS. seca650rj
Old Nov 1, 2008 | 01:44 PM
Is the latch tripped to the closed position while the hatch is open? If it is, it will not lock.
Alternately, you can try activating the latch manually (I did a thread on the manual release if you do a search).
Old Nov 1, 2008 | 09:17 PM
Seca650RJ's Avatar
Actually for whatever reason, it starting latching again. I tool it to the stealership, where of course, there are no techs in on saturday. So we went to Wally World and ppickud up a couple of bungees to hold it shut till monday, when we could get the car in. A bit of pressure from the bungee freed up whatever was stuck and it works fine now. Did see a real nice black 09 with the 3rd window delete, 5 speed and 2.4l engine. Looked real sharp.
Old Nov 2, 2008 | 12:02 AM
halfpanel08's Avatar
keep watch on it, and take it in if it does it again
let them fix their problems. (that is if u got warranty)
molecule
Apr 10, 2017 03:57 PM
sportshots
Aug 3, 2015 11:26 AM
havoc3d
Aug 9, 2011 05:32 PM
Rickh
Dec 19, 2009 10:55 AM
GhstRider
47
Mar 5, 2007 07:18 AM
