'07-'09 & '10-'11 Powertrain Parts Coverage List
Old 03-03-2009, 08:35 AM
Drive Line/Axle
Cap, Wheel Nut -- Replace
Cap, Hub Assembly -- Front -- R&R or Replace
Cap, Hub Assembly -- Rear -- R&R or Replace
Cap, Hub Assembly -- All -- R&R or Replace
Bearing, Front Wheel -- Right -- Adjust
Bearing, Front Wheel -- Both -- Adjust
Cap, Front Wheel Hub Dust -- Right -- Replace
Cap, Front Wheel Hub Dust -- Left -- Replace
Cap, Front Wheel Hub Dust -- Both -- Replace
Bearing, Front Wheel -- Inner -- Right -- Replace
Bearing, Front Wheel -- Inner -- Left -- Replace
Bearing, Front Wheel -- Inner -- Both -- Replace
Bearing, Front Wheel -- Outer -- Right -- Replace
Bearing, Front Wheel -- Outer -- Left -- Replace
Bearing, Front Wheel -- Outer -- Both -- Replace
Bearing, Front Wheel -- Inner and Outer -- Right -- Replace
Bearing, Front Wheel -- Inner and Outer -- Left -- Replace
Bearing, Front Wheel -- Inner and Outer -- Both -- Replace
Seal, Front Wheel Bearing -- Right -- Replace
Seal, Front Wheel Bearing -- Left -- Replace
Seal, Front Wheel Bearing -- Both -- Replace
Bearing and Hub Assembly, Front Wheel -- Right -- Replace
Bearing and Hub Assembly, Front Wheel -- Left -- Replace
Bearing and Hub Assembly, Front Wheel -- Both -- Replace
Axle, I-Beam -- Replace
Bearings, Rear Wheel -- Left -- Adjust
Bearings, Rear Wheel -- Both -- Adjust
Bearings, Rear Wheel -- Single or Front Tandem -- Right -- Replace
Bearings, Rear Wheel -- Single or Front Tandem -- Left -- Replace
Bearings, Rear Wheel -- Rear Tandem -- Right -- Replace
Bearings, Rear Wheel -- Rear Tandem -- Left -- Replace
Bearings, Rear Wheel -- Right -- Replace
Bearings, Rear Wheel -- Left -- Replace
Bearings, Rear Wheel -- Both -- Replace
Seal, Rear Wheel Inner Oil (One Wheel) -- Single or Front Tandem -- Right -- Replace
Seal, Rear Wheel Inner Oil (One Wheel) -- Single or Front Tandem -- Left -- Replace
Seal, Rear Wheel Bearing Inner Oil (One Wheel) -- Rear Tandem -- Right -- Replace
Seal, Rear Wheel Bearing Inner Oil (One Wheel) -- Rear Tandem -- Left -- Replace
Bearing and Hub Assembly, Rear Wheel -- Right -- Replace
Bearing and Hub Assembly, Rear Wheel -- Left -- Replace
Bearing and Hub Assembly, Rear Wheel --Both -- Replace
Hub Assembly, Rear Wheel -- Both -- Replace
Hub Assembly, Rear Wheel -- Single or Front Tandem -- Right -- Replace
Hub Assembly, Rear Wheel -- Single or Front Tandem -- Left -- Replace
Hub Assembly, Rear Wheel -- Rear Tandem -- Right -- Replace
Hub Assembly, Rear Wheel -- Rear Tandem --Left -- Replace
Axle Assembly, Rear -- Replace
Angularity, Drive Line -- Check and Correct
Actuator, Front Differential Locking -- Replace
Seal, Front Differential Shifter -- Replace
Bearing, Center Support (between Trans and Rear Differential) -- Replace
Slip Joint, Propeller Shaft (between Trans and Rear Differential) -- Replace
Universal Joint, Front Propeller Shaft -- Front -- Replace
Universal Joint, Front Propeller Shaft -- Rear -- Replace
Universal Joint, Front Propeller Shaft -- Both -- Replace
Universal Joint, Rear Propeller Shaft -- Front -- Replace
Universal Joint, Rear Propeller Shaft -- Rear -- Replace
Universal Joint, Rear Propeller Shaft -- Intermediate -- Replace
Universal Joint, Rear Propeller Shaft -- Both -- Replace
Propeller Shaft, Front of Transfer Case -- Replace
Propeller Shaft, Intermediate -- Replace
Propeller Shaft, Rear -- Replace
Propeller Shaft, Intermediate Axle -- Replace
Propeller Shaft Assembly (between Trans and Rear Differential) - R&R or Replace
Bracket, Driveline Support -- Replace
Support, Driveline -- R&R
Support, Driveline -- Replace
Tube, Driveline Torque -- Replace
Shaft, Front Differential Output -- Front -- Right -- Replace
Shaft, Front Differential Output -- Front -- Left -- Replace
Shaft, Front Differential Output -- Front -- Both -- Replace
Seals, Front Differential Output Shaft -- Front -- Right -- Replace
Seals, Front Differential Output Shaft -- Front -- Left -- Replace
Seals, Front Differential Output Shaft -- Front -- Both -- Replace
Shaft Assembly, Intermediate -- Replace
Seal, Intermediate Shaft -- Replace
Bearing, Intermediate Shaft (Front Drive Axle) -- Replace
Shaft, Inner Axle (Front Drive Axle) -- Replace
Halfshaft, Front Drive -- Front -- Right -- R&R
Halfshaft, Front Drive -- Front -- Left -- R&R
Halfshaft, Front Drive -- Front -- Both -- R&R
Halfshaft, Front Drive -- Front -- Right -- Replace
Halfshaft, Front Drive -- Front -- Left -- Replace
Halfshaft, Front Drive -- Front -- Both -- Replace
Halfshaft, Rear Drive -- Rear -- Right -- Replace
Halfshaft, Rear Drive -- Rear -- Left -- Replace
Halfshaft, Rear Drive -- Rear -- Both -- Replace
Halfshaft, Rear Drive -- Rear -- Right -- R&R
Halfshaft, Rear Drive -- Rear -- Left -- R&R
Halfshaft, Rear Drive -- Rear -- Both -- R&R
Shaft, Axle -- Intermediate -- Replace
Shaft, Axle -- Rear Axle -- Right -- Replace
Shaft, Axle -- Rear Axle -- Left -- Replace
Shaft, Axle -- Rear Axle -- Both -- Replace
Shaft, Axle -- Single or Front Tandem -- Right -- Replace
Shaft, Axle -- Single or Front Tandem -- Left -- Replace
Shaft, Axle -- Rear Tandem -- Right -- Replace
Shaft, Axle -- Rear Tandem -- Left -- Replace
Boot (Seal), Axle Shaft Joint -- One -- Replace
Seal, Axle Shaft Inner -- Rear -- Right -- Replace
Seal, Axle Shaft Inner -- Rear -- Left -- Replace
Seal, Axle Shaft Inner -- Rear -- Both -- Replace
Seal, Axle Shaft Oil -- Front Axle -- Right -- Replace
Seal, Axle Shaft Oil -- Front Axle -- Left -- Replace
Seal, Axle Shaft Oil -- Front Axle -- Both -- Replace
Seal, Axle Shaft Oil -- Rear Axle -- Right -- Replace
Seal, Axle Shaft Oil -- Rear Axle -- Left -- Replace
Seal, Axle Shaft Oil -- Rear Axle --Both -- Replace
Bearing, Axle Shaft -- Rear Axle -- Right -- Replace
Bearing, Axle Shaft -- Rear Axle -- Left -- Replace
Bearing, Axle Shaft -- Rear Axle -- Both -- Replace
Bearing, Rear Wheel -- Right -- Replace
Bearing, Rear Wheel -- Left -- Replace
Bearing, Rear Wheel -- Both -- Replace
Seal, Hub Oil -- Rear Axle -- Right -- Replace
Seal, Hub Oil -- Rear Axle -- Left -- Replace
Seal, Hub Oil -- Rear Axle -- Both -- Replace
Gasket, Axle Oil -- Rear Axle -- Right -- Replace
Gasket, Axle Oil -- Rear Axle -- Left -- Replace
Gasket, Axle Oil -- Rear Axle -- Both -- Replace
Cover/Gasket, Differential -- Front -- Replace
Cover and/or Gasket, Differential -- Rear Differential -- Replace
Cover and/or Gasket, Differential -- Rear Differential -- Right -- Replace
Cover and/or Gasket, Differential -- Rear Differential -- Left -- Replace
Cover and/or Gasket, Differential -- Rear Differential -- Rear -- Replace
Seal, Pinion Shaft Oil -- Front Differential -- Replace
Seal, Pinion Shaft Oil -- Rear Differential -- Replace
Seal, Pinion Shaft Oil -- Single or Front Tandem -- Replace
Seal, Pinion Shaft Oil -- Rear Tandem -- Replace
Seal, Differential Carrier Extension Cover -- Replace
Flange, Pinion Shaft -- Front Differnetial -- Replace
Flange, Pinion Shaft -- Rear Differnetial -- Replace
Tube Assembly, Front Differential Output Shaft -- R&R or Replace
Carrier Assembly -- Front Differential -- R&R
Carrier Assembly -- Rear Differential -- R&R
Carrier Assembly -- Single or Front Tandem -- R&R
Carrier Assembly -- Rear Tandem -- R&R
Carrier Assembly Complete -- Single or Front Tandem -- Recondition
Carrier Assembly Complete -- Rear Tandem -- Recondition
Carrier Assembly Complete -- Front Differential -- Replace
Carrier Assembly Complete -- Rear Differential -- Replace
Pinion Shaft, Pinion Gears and/or Side Gears, Differential -- Rear Differential -- Replace
Gears, Differential Side and Pinion -- Replace
Case, Differential -- Rear Differential -- Replace
Plates, Limited Slip Clutch -- Replace
Bearings, Side -- Rear Differential -- Replace
Bearing, Pinion (Front and/or Rear) -- Rear Differential -- Replace
Ring Gear and Pinion -- Front Differential -- Replace
Ring Gear and Pinion -- Rear Differential -- Replace
Pad, Carrier Ring Gear Thrust -- Adjust
Filter, Carrier Oil -- Replace
Seal, Thru-Shaft Output -- Replace
Shaft, Thru-Shaft Output -- Replace
Bearing and/or Housing, Thru-Shaft -- Replace
Retainer, Thru-Shaft Output Bearing -- Replace
Shift Assembly, Axle (Electric) -- R&R or Replace
Motor, Axle Shift -- Replace
Block, Axle Shift Sliding -- Replace
Housing Assembly, Differential -- Rear Differential -- Replace
Seal, Rear Axle Housing Drain -- Replace
Bushing, Rear Differential Damping -- Right -- Replace
Bushing, Rear Differential Damping -- Left -- Replace
Bushing, Rear Differential Damping -- Both -- Replace
Housing, Axle -- Single or Front Tandem -- Rear -- Replace
Housing, Axle -- Rear Tandem -- Replace
Rear Differential Assembly (Complete) -- Replace
Axle Assembly, Rear -- Single or Front Tandem -- Replace
Axle Assembly, Rear Tandem -- Replace
Ventilator, Axle -- Front -- Replace
Ventilator, Axle -- Rear -- Replace
Plug, Differential Carrier Drain -- Replace
Plug, Differential Carrier Fill -- Replace
Old 03-03-2009, 08:36 AM
Engine
Manifold, Exhaust -- Right Bank -- Replace
Manifold, Exhaust -- Left Bank -- Replace
Manifold Converter Assembly, Exhaust -- Right Bank -- Replace
Manifold Converter Assembly, Exhaust -- Left Bank -- Replace
Manifold Converter Assembly, Exhaust -- Single -- Replace
Manifold and/or Gasket, Exhaust -- Replace
Manifold, Exhaust -- Replace
Spacer, Intake -- Replace
Cover, Upper Intake Manifold -- Replace
Cover and/or Gasket, Engine Block Valley -- Replace
Manifold, Intake -- Replace
Gasket, Intake Manifold -- Replace
Manifold, Intake (Upper) -- Replace
Gasket, Intake Manifold (Upper) -- Replace
Manifold, Intake (Lower) -- Replace
Gasket, Intake Manifold (Lower) -- Replace
Manifold, Intake (Right) -- Replace
Gasket, Intake Manifold (Right) -- Replace
Manifold, Intake (Left) -- Replace
Gasket, Intake Manifold (Left) -- Replace
Manifold, Intake (Center) -- Replace
Gasket, Intake Manifold (Center) -- Replace
Cover, Valve Rocker Arm Upper -- Right -- Replace
Cover, Valve Rocker Arm Upper -- Left -- Replace
Cover, Valve Rocker Arm Upper -- Both -- Replace
Cover and/or Gasket, Rocker -- Right Bank -- Replace
Cover and/or Gasket, Rocker -- Left Bank -- Replace
Cover and/or Gasket, Rocker -- Both Banks -- Replace
Cover and/or Gasket, Rocker -- Replace
Cover and/or Gasket, Camshaft Housing -- Right -- Replace
Cover and/or Gasket, Camshaft Housing -- Left -- Replace
Cover and/or Gasket, Camshaft Housing -- Both -- Replace
Cover and/or Gasket, Camshaft Housing -- One Piece -- Replace
Rocker Arm, Intake -- One Cyl -- Replace
Rocker Arm -- One Cylinder, Exhaust -- Replace
Rocker Arm, Exhaust -- One or All -- Replace
Rocker Arm, Intake (One or All) -- Right (Rear) Head -- Replace
Rocker Arm, Intake (One or All) -- Left (Front) Head -- Replace
Rocker Arm, Exhaust (One or All) -- Right (Rear) Head -- Replace
Rocker Arm, Exhaust (One or All) -- Left (Rear) Head -- Replace
Rocker Arm - One Cyl -- Right Bank -- Replace
Rocker Arm - One Cyl -- Left Bank -- Replace
Rocker Arm - One Cyl -- Both Banks -- Replace
Rocker Arm - One Cyl -- Replace
Rocker Arm - One or All -- Replace
Rocker Arm Shaft and/or Assemblies -- Right Bank -- Replace
Rocker Arm Shaft and/or Assemblies -- Left Bank -- Replace
Rocker Arm Shaft and/or Assemblies -- Both Banks -- Replace
Shaft, Rocker Arm -- One or Both -- Replace
Arm and/or Pivot, Rocker -- One Cyl -- Right Bank -- Replace
Arm and/or Pivot, Rocker -- One Cyl -- Left Bank -- Replace
Arm and/or Pivot, Rocker -- One Cyl -- Both Banks -- Replace
Stud, Rocker Arm -- One Stud -- Right Bank -- Replace
Stud, Rocker Arm -- One Stud -- Left Bank -- Replace
Valve Lash -- Adjust
Plug, Cylinder Head Oil -- Right Bank -- Replace
Plug, Cylinder Head Oil -- Left Bank -- Replace
Gasket, Cylinder Head -- Right Bank -- Replace
Gasket, Cylinder Head -- Left Bank -- Replace
Gasket, Cylinder Head -- Both Banks -- Replace
Gasket, Cylinder Head -- Replace
Valve, Oil Flow Check -- Replace
Head, Cylinder -- Right Bank -- Replace
Head, Cylinder -- Left Bank -- Replace
Head, Cylinder -- Both Banks -- Replace
Head, Cylinder -- Replace
Valve -- One Cyl -- Right Bank -- Recondition or Replace
Valve -- One Cyl -- Left Bank -- Recondition or Replace
Valve -- One Cyl -- Both Banks -- Recondition or Replace
Valve -- One Cyl -- Recondition or Replace
Valve -- Replace
Guide, Valve -- One Cyl -- Replace
Spring, Cap and/or Seal, Valve -- One Cyl -- Right Bank -- Replace
Spring, Cap and/or Seal, Valve -- One Cyl -- Left Bank -- Replace
Spring, Cap and/or Seal, Valve -- All Seats -- Intake -- Replace
Spring, Cap and/or Seal, Valve -- All Seats -- Exhaust -- Replace
Spring, Cap and/or Seal, Valve -- All Seats -- Both -- Replace
Spring, Cap and/or Seal, Valve -- One Cyl -- Both Banks -- Replace
Spring, Cap and/or Seal, Valve -- One Cyl -- Replace
Spring, Cap and/or Seal, Valve -- Intake -- Replace
Spring, Cap and/or Seal, Valve -- Exhaust -- Replace
Spring, Cap and/or Seal, Valve -- Both -- Replace
Adjuster, Valve -- One Cyl -- Replace
Adjuster, Hydraulic Valve Lash -- One Cylinder, Intake -- Replace
Adjuster, Hydraulic Valve Lash -- One Cylinder, Exhaust -- Replace
Push Rod -- One Cyl -- Right Bank -- Replace
Push Rod -- One Cyl -- Left Bank -- Replace
Push Rod -- One Cyl -- Both Banks -- Replace
Guide, Push Rod -- One Cyl -- Right Bank -- Replace
Guide, Push Rod -- One Cyl -- Left Bank -- Replace
Guide, Push Rod -- One Cyl -- Both Banks -- Replace
Manifold, Valve Lifter Oil -- Replace
Gasket, Valve Lifter Oil Manifold -- Replace
Lifter, Valve -- Right Bank -- Replace
Lifter, Valve -- Left Bank -- Replace
Lifter, Valve -- Both Banks -- Replace
Lifter, Valve -- Replace
Lifter, Valve -- Intake -- Replace
Lifter, Valve -- Exhaust -- Replace
Lifter, Valve -- Both -- Replace
Lifters, Intake (One or All) -- Right Head -- Replace
Lifters, Intake (One or All) -- Left Head -- Replace
Lifters, Exhaust (One or All) -- Right Head -- Replace
Lifters, Exhaust (One or All) -- Left Head -- Replace
Guide and/or Clamp, Lifter -- One Cyl -- Right Bank -- Replace
Guide and/or Clamp, Lifter -- One Cyl -- Left Bank -- Replace
Guide and/or Clamp, Lifter -- One Cyl -- Both Banks -- Replace
Bracket, Timing Belt Tensioner -- Replace
Balancer, Harmonic -- Replace
Seal, Crankcase Front Cover -- Replace
Seal, Timing Cover Oil -- Replace
Cover and/or Gasket, Crankcase Front -- Replace
Cover and/or Gasket, Timing -- Replace
Guide, Timing Chain -- Replace
Guides, Timing Chain -- Replace
Tensioner and/or Shoe, Timing Chain -- Replace
Tensioner, Secondary Timing Chain - Right Bank -- Replace
Tensioner, Secondary Timing Chain - Left Bank -- Replace
Tensioner, Timing Chain -- Replace
Seal, Front Crankshaft Oil -- Replace
Dust Cover and/or Gaskets, Camshaft Drive Belt -- Upper -- Replace
Belt, Camshaft Timing -- Replace
Belt, Camshaft Timing -- Adjust
Cover, Camshaft Drive Belt -- Front -- Replace
Pulley, Camshaft Idler -- Replace
Tensioner, Timing Belt -- Replace
Pulley, Timing Belt Idler (One or Both) -- Replace
Housing Assembly and/or Seal, Camshaft Position Sensor -- R&R or Replace
Chain, Camshaft Timing -- Replace
Oil Filter, Camshaft Position Actuator Solenoid Valve -- Replace
Solenoid Valve, Camshaft Position Actuator -- Replace
Actuator Sprocket, Camshaft Position -- Replace
Camshaft Position Actuator Replacement
Chain, Camshaft Secondary Drive -- Right Bank -- Replace
Chain, Camshaft Secondary Drive -- Left Bank -- Replace
Tensioner and/or Guide, Camshaft Primary Chain -- Replace
Sprocket, Crankshaft Timing -- Replace
Sprocket, Camshaft Timing -- Right Bank -- Intake -- Replace
Sprocket, Camshaft Timing -- Right Bank -- Exhaust -- Replace
Sprocket, Camshaft Timing -- Left Bank -- Intake -- Replace
Sprocket, Camshaft Timing -- Left Bank -- Exhaust -- Replace
Camshaft Timing Gear/Chain Set Replacement
Sprocket, Camshaft Timing -- Replace
Housing, Timing Cover -- Replace
Idler Sprocket and/or Bearing, Timing Chain -- Replace
Bearings, Camshaft -- Replace
Gear, Injection Pump Driven -- Replace
Camshaft -- Replace
Seal, Camshaft Front Oil -- Replace
Seal, Camshaft -- One Seal -- Right Bank -- Replace
Seal, Camshaft -- One Seal -- Left Bank -- Replace
Camshaft -- Intake -- Replace
Camshaft -- Exhaust -- Replace
Camshaft -- Both -- Replace
Housing and/or Gasket, Camshaft Position Actuator -- Replace
Valve, Camshaft Position Actuator Spool -- Replace
Magnet, Camshaft Postion Actuator -- Replace
Camshaft -- Right Bank -- Intake -- Replace
Camshaft -- Right Bank -- Exhaust -- Replace
Camshaft -- Left Bank -- Intake -- Replace
Camshaft -- Left Bank -- Exhaust -- Replace
Plate and/or Gasket Assembly, Cylinder Head Opening -- Replace
Plug and/or Seal, Cam Drive Access -- Replace
Gear(s), Balance Shaft -- Replace
Shadt and Bearing, Balance -- R&R or Replace
Cap, Oil Filler -- Replace
Breather, Crankcase Ventilation -- Replace
Oil Level Indicator Replacement
Tube, Oil Level Indicator -- Replace
Tube, Engine Oil Filler Rear -- Replace
Pipe, Oil Intake -- Replace
Cap and/or Seal, Oil Filter -- Replace
Adapter and/or Gasket, Oil Filter -- Replace
Valve, Oil Filter By-Pass -- Replace
Valve, Valve Lifter Oil Solenoid -- Replace
Module, Engine Oil Flow Control -- Replace
Switch, Engine Oil Flow Control -- Replace
Valve, Oil Pressure Relief -- Replace
Oil Tank Replacement
Oil Tank Outlet Hose Replacement
Plug and/or Gasket, Oil Pan Drain -- Replace
Pan and/or Gasket, Oil -- Replace
Baffle, Oil Pan -- Replace
Deflector, Oil Wheel -- Replace
Crankcase and/or Gasket -- Replace
Gear, Oil Pump Drive -- R&R or Replace
Pump, Engine Oil -- Replace
Pump Cover and/or Gears, Oil -- Recondition or Replace
Drive, Oil Pump -- Replace
Cap and/or Seal, Oil Pump Drive -- Replace
Manifold and/or Gasket, Engine Oil -- Replace
Tube/Screen and/or Gasket, Oil Pickup -- Replace
Housing and/or Gasket, Rear Main Seal -- Replace
Shaft Assemblies, Balance -- Replace
Bearings, Balance Shaft -- Replace
Drive Chain, Balance Shaft -- Replace
Tensioner, Balance Shaft -- Replace
Drive Sprocket, Balance Shaft -- Replace
Driven Sprocket, Balance Shaft -- Replace
Chain Guide, Balance Shaft -- Replace
Seal, Crankshaft Rear Main -- Replace
Bearing, Crankshaft Main -- One Bearing -- Replace
Bearing, Connecting Rod -- One Bearing -- Replace
Seal, Lower Crankcase -- Replace
Scraper, Crankshaft Oil -- Replace
Crankshaft -- Replace
Piston, Rod and/or Rings -- One Cyl -- Right Bank -- Replace
Piston, Rod and/or Rings -- One Cyl -- Left Bank -- Replace
Piston, Rod and/or Rings -- One Cyl -- Both Banks -- Replace
Piston, Rod and/or Rings -- One Cyl -- Replace
Sleeve, Cylinder Liner -- Replace
Flywheel (Automatic Transmission/Transaxle) -- Replace
Flywheel (Manual Transmission/Transaxle) -- Replace
Cover, Flywheel -- Replace
Housing, Flywheel -- Replace
Old 03-03-2009, 08:37 AM
Engine Continued
Mount, Engine -- Front -- Right -- Replace
Mount, Engine -- Front -- Left -- Replace
Mount, Engine -- Front -- Replace
Mount, Engine -- Front of Engine -- Replace
Mount, Engine -- Front - Both -- Replace
Mount, Engine -- Rear - Right -- Replace
Mount, Engine -- Rear - Left -- Replace
Mount, Engine -- Rear - Center -- Replace
Mount, Engine -- Rear - Both -- Replace
Strut, Engine Mounting -- Replace
Bracket, Engine Torque Strut -- Right -- Replace
Bracket, Engine Torque Strut -- Left -- Replace
Plug, Expansion -- Replace
Plug, Oil Gallery -- Replace
Plug or Cover and/or Gasket, Camshaft Rear Bearing -- Replace
Block, Engine Fitted -- Replace
Block, Engine Cylinder -- Replace
Engine, Partial -- Replace
Engine, Universal -- Replace
Engine Assembly -- Replace
Cover and/or Gasket, Oil Pan -- Replace
Cover and/or Gaskets, Coolant Pump -- Replace
Housing and/or Gasket, Coolant Pump -- Replace
Pump and/or Gasket, Coolant -- Replace
Thermostat, Outlet and/or Gasket -- Replace
Plug, Water Jacket -- Right -- Replace
Plug, Water Jacket -- Left -- Replace
Pump, Electric Auxiliary Coolant -- Replace
Interrupter, Camshaft -- Replace
Ring, Crankshaft Position Sensor Reluctor -- Replace
Motor Assembly, Starter -- Replace
Regulator (Limiter), Fuel Pressure -- Replace
Pump and/or Gasket, Fuel -- Replace
Pump, Auxiliary Fuel Tank Transfer -- Replace
Regulator and/or Gaskets, Fuel Pressure -- Replace
Pump, Fuel (Engine Mounted) -- R&R or Replace
Injector, Fuel -- Replace
Rail, Fuel -- Replace
Intercooler Assembly -- Replace
Pipe/Duct, Turbo Outlet (to Change Air Cooler) -- Replace
Pipe/Duct, Charge Air Cooler Outlet (to Intake Manifold) -- Replace
Pipe, Inlet (Turbo to Intercooler) -- Replace
Pipe, Turbo to Intercooler Inlet (Both) -- Replace
Flexible Hose (Intercooler) (One) -- Replace
Flexible Hose (Intercooler) (Two) -- Replace
Inlet Pipe, Turbo to Charge Air Cooler (Intercooler) -- Replace
Rubber Hose, Turbo to Inlet Pipe (Intercooler) -- Replace
Pump Assembly, Charge Air Cooler Coolant -- Replace
Pipe, Turbocharger Outlet -- Replace
Pipe, Charge Air Cooler Inlet -- Replace
Pipe, Charge Air Cooler Outlet -- Replace
Hose, Charge Air Cooler Inlet -- Replace
Hose, Charge Air Cooler Outlet -- Replace
Actuator, Turbocharger Waste Gate -- Replace
Solenoid, Waste Gate -- Replace
Valve, Turbocharger Vane Position Solenoid -- Replace
Hose, Turbocharger to Charge Air Cooler -- One -- Replace
Hose, Turbocharger to Charge Air Cooler -- Both -- Replace
Turbocharger Assembly -- R&R
Turbocharger Assembly -- Replace
Pipe/Hose, Turbocharger Oil -- Replace
Hose and/or Pipe, Turbocharger Oil Return -- Replace
Line and/or Pipe, Turbocharger Oil Feed -- R&R or Replace
Cable, Charge Air Bypass -- Replace
Actuator, Supercharger Boost Control -- Replace
Manifold, Vacuum Source Supercharger Boost -- Replace
Solenoid, Supercharger Boost -- Replace
Gasket, Supercharger -- Replace
Supercharger Assembly -- Replace
Dampener, Fuel Injection Fuel Rail -- Replace
Rail, Common Fuel (Diesel) -- Replace
Line, Fuel Injection High Pressure (Diesel) -- Right -- R&R or Replace
Line, Fuel Injection High Pressure (Diesel) -- Left -- R&R or Replace
Line, Fuel Injection High Pressure (Diesel) -- One -- R&R or Replace
Line, Fuel Injection High Pressure (Diesel) -- All -- R&R or Replace
Nozzle and/or Seal, Fuel Injection (Diesel) -- One Nozzle -- Right -- Clean or Replace
Nozzle and/or Seal, Fuel Injection (Diesel) -- One Nozzle -- Left -- Clean or Replace
Nozzle and/or Seal, Fuel Injection (Diesel) -- All Nozzles -- Clean or Replace
Pump, Fuel Injection (Diesel) -- R&R
Pump, Fuel Injection (Diesel) -- Replace
Connector Assembly, Fuel Return Line (Diesel) -- R&R or Replace
Gear and/or Advance Timing Mechanism, Fuel Injection Pump -- Replace
Coupling Assembly, Fuel Injection Pump Drive (Diesel) -- Replace
Valve, PCV -- Replace
Tank Assembly, Intake Manifold Tuning Valve Actuator Vacuum -- Replace
Powertrain Control Module Engine Reprogramming with SPS
Pwertrain Control Module Transmission Reprogramming wiht SPS
Powertrain Control Module Replacement
Old 03-03-2009, 08:38 AM
Arm, Clutch -- Replace
Shaft and/or Bushings, Clutch Fork -- Replace
Cylinder, Concentric Slave -- Replace
Cylinder, Clutch Actuator -- R&R or Replace
Bearing, Clutch Release -- Replace
Fork and/or Ball Stud, Clutch Release -- Replace
Housing, Clutch -- Replace
Plug and/or Washer, Transaxle Fluid Drain -- Replace
Seal, Transmission Extension Rear Oil -- Replace
Seal, Main Shaft Rear -- Replace
Flange, Propeller Shaft Transmission -- Replace
Gasket, Mainshaft Rear Bearing Retainer -- Replace
Retainer and/or Gasket, Front Bearing -- Replace
Cover and/or Gasket, Transmission/Transaxle Shift -- R&R or Replace
Cover and/or Gasket, Shift Detent -- Replace
Mount, Transmission/Transaxle -- Right -- Replace
Mount, Transmission/Transaxle -- Left -- Replace
Mount, Transmission/Transaxle -- Front -- Replace
Mount, Transmission/Transaxle -- Rear -- Replace
Mount, Transmission/Transaxle -- Both -- Replace
Bracket, Transmission/Transaxle Mount -- Replace
Bracket, Transaxle Strut Mount (to Cradle) -- Replace
Valve, Air Slave -- R&R or Replace
Valve, Transmission Splitter (Three Position) -- Replace
Valve, Range Control (Two Position) -- Replace
Cover and/or Gasket, Reverse Idler -- Replace
Rear Cover, Transaxle -- R&R or Replace
Hose and/or Tube, Transaxle Vent -- Replace
Case Assembly, Auto Transaxle -- Replace
Transmisson Assembly -- Recondition
Transmission/Transaxle Assembly -- Replace
Case -- R&R or Replace
Input Shaft Bearing Replacement
Transmission Fluid Pump Replacement
Cover and/or Gasket, Power Take-Off -- R&R or Replace
Gear -- 6th Speed Gear -- R&R or Replace
Gear -- 4th Speed Gear -- R&R or Replace
Gear -- Reverse Gear -- R&R or Replace
Gear --5th Speed Gear -- R&R or Replace
Gear --3rd Speed Gear -- R&R or Replace
Gear --2nd Speed Gear -- R&R or Replace
Gear --1st Speed Gear -- R&R or Replace
Synchronizers -- 1st-2nd -- R&R or Replace
Synchronizers -- 3rd-4th -- R&R or Replace
Synchronizers -- 5th-Reverse -- R&R or Replace
Shaft, Input -- R&R or Replace
Mainshaft -- R&R or Replace
Idler Assembly, Reverse -- R&R or Replace
Countershaft and/or Bearing(s) -- Countershaft -- R&R or Replace
Countershaft and/or Bearing(s) -- Countershaft Bearing(s) -- R&R or Replace
Front Housing/Sealer -- R&R or Replace
Rear Housing/Sealer -- R&R or Replace
Fork and/or Shaft, Shift -- 1st-2nd -- R&R or Replace
Fork and/or Shaft, Shift -- 3rd-4th -- R&R or Replace
Fork and/or Shaft, Shift -- 5th-Reverse -- R&R or Replace
Socket, Shift -- R&R or Replace
Tower, Shift -- R&R or Replace
Gear -- 5th & 6th Driven -- R&R or Replace
Gear -- 6th Drive -- R&R or Replace
Synchronizers -- 5th-6th -- R&R or Replace
Synchronizers -- Reverse -- R&R or Replace
Fork and/or Shaft, Shift -- 5th-6th -- R&R or Replace
Fork and/or Shaft, Shift -- Reverse -- R&R or Replace
Fork and/or Shaft, Shift -- 5th-6th and Reverse Shaft -- R&R or Replace
Shaft and/or Bearing, Counter Shaft Extension -- Replace
Plate and/or Sealant, Adapter -- Replace
Seal, Selector Shaft -- Replace
Retainer, Main Shaft Bearing -- Replace
Seal, Input Shaft -- Replace
Bracket, Shift Control Lever -- Replace
Shaft, Shift Control Lever -- Replace
Lever Assembly, Reverse Shift -- Replace
Shaft Assembly, Shift Control -- Replace
Synchronizers -- 6th -- R&R or Replace
Synchronizers -- 4th-6th -- R&R or Replace
Synchronizers -- 2nd-3rd -- R&R or Replace
Fork, Shift -- 1st-Reverse -- R&R or Replace
Fork, Shift -- 2nd-3rd -- R&R or Replace
Fork, Shift -- 4th-5th -- R&R or Replace
Fork, Shift -- 6th -- R&R or Replace
Seals, Axle (Transaxle) -- Right -- Replace
Seals, Axle (Transaxle) -- Left -- Replace
Seals, Axle (Transaxle) -- Both -- Replace
Differential Assembly -- R&R or Replace
Bearings, Differential Gear Assembly Side -- R&R or Replace
Ring Gear, Differential Gear Assembly -- R&R or Replace
Pinion and Side Gears, Differential Gear Assembly -- R&R or Replace
Speedometer Gear, Differential Case Assembly -- R&R or Replace
Case, Differential -- R&R or Replace
Shaft and/or Gears, Intermediate -- Shaft -- Replace
Shaft and/or Gears, Intermediate -- 1st Gear -- Replace
Shaft and/or Gears, Intermediate -- 2nd Gear -- Replace
Shaft and/or Gears, Input -- 5th Gear -- R&R or Replace
Shaft and/or Gears, Input -- 4th Gear -- R&R or Replace
Shaft and/or Gears, Input -- 3rd Gear -- R&R or Replace
Shaft and/or Gears, Input -- Input Shaft -- R&R or Replace
Shaft and/or Gears, Input Cluster -- R&R or Replace
Shaft and/or Gears, Output - 5th Gear -- R&R or Replace
Shaft and/or Gears, Output - 4th Gear -- R&R or Replace
Shaft and/or Gears, Output - 3rd Gear -- R&R or Replace
Shaft and/or Gears, Output - 2nd Gear -- R&R or Replace
Shaft and/or Gears, Output - 1st Gear -- R&R or Replace
Shaft and/or Gears, Output -- Output Shaft -- R&R or Replace
Shaft and/or Gears, Output -- Reverse -- R&R or Replace
Housing, Bearing Plate -- Replace
Synchronizers -- 5th -- R&R or Replace
Clutch or Differential Housing -- R&R or Replace
Bearing/Sleeve Assembly, Input Shaft -- R&R or Replace
Bearing, Input Shaft Roller (Quill) -- Replace
Bearing/Sleeve Assembly, Output Shaft -- R&R or Replace
Bearing, Output Shaft Roller -- Replace
Transaxle Case -- R&R or Replace
Fork and/or Shaft, Shift -- 5th -- R&R or Replace
Fork and/or Shaft, Shift -- Reverse Enable -- R&R or Replace
Transfer Case Module Reprogramming wth SPS
Module, Transfer Case Shift -- Replace
Actuator Assembly, Transfer Case -- Replace
Seal, Transfer Case -- Replace
Seal, Transfer Case Front Output Shaft -- Replace
Seal, Transfer Case Rear Output Shaft -- Replace
Seal, Transfer Case Input Shaft -- Replace
Gasket, Transfer Case Bearing Retainer -- Front Output Shaft (Front) -- Replace
Gasket, Transfer Case Bearing Retainer -- Front Output Shaft (Rear) -- Replace
Shaft, Transfer Case Output -- Replace
Gasket, Transfer Case to Adapter -- Replace
Gasket or Sealer, Transfer Case Rear Output Shaft Housing -- Replace
Bushing, Transfer Case Output -- Replace
Housing, Rear Output Shaft -- Replace
Plug, Transfer Case Drain -- Replace
Plug, Transfer Case Fill -- Replace
Transfer Case Assembly -- R&R
Transfer Case Assembly -- Replace
Shift Lock Control -- Replace
Actuator, Automatic Transmission Shift Lock Control -- Adjust
Seal, Shift Lever -- Replace
Transmission Control Module Transmission Reprogramming with SPS
Module, Transmission Control -- Replace
Indicator, Transmission/Transaxle Oil Level (Dipstick) -- Replace
Tube and/or Seal, Transmission/Transaxle Filler -- Replace
Plug and/or Seal, Transmssion/Transaxle Fluid Drain -- Replace
Flange, Propeller Shaft Drive -- Replace
Cover and/or Gasket, Power Take-Off -- Replace
Transmisson Converter Cover Replacement
Bolts, Converter to Flywheel -- Replace
Solenoid, Pressure Control -- Replace
Seal, Extension Housing Rear -- Replace
Bearing, Extension Housing -- Replace
Flange, Transmission Companion -- Replace
Plug, Transmission Sealed -- Replace
Seal, Transmission Rear Oil -- Replace
Housing and/or Housing to Case O-Ring Seal or Gasket, Extension -- Replace
Scavenger Pipe and/or Seal -- Replace
Differential Carrier and Differential Final Assembly -- R&R or Replace
Final Drvie Sun Gear -- R&R or Replace
Parking Gear -- R&R or Replace
Final Drive Sun Gear Shaft -- R&R or Replace
Gear, Final Drive Internal -- R&R or Replace
4th Servo -- R&R or Replace
Governor Assembly -- Replace
Timing Solenoid -- Replace
Lock-Up Solenoid -- Replace
Clutch, Sprag -- Replace
Pan and/or Gasket, Transmisison/Transaxle Oil -- Replace
Shaft Manual -- Replace
Lever, Detent -- Replace
Rod, Park Actuator -- Replace
Screens and/or Seals, Scavenger -- Replace
Accumulator, 1-2 -- R&R or Replace
Accumulator Assembly, 1-2, 2-3 -- R&R or Replace
Servo Assembly, Manual 2-1 -- R&R or Replace
Tube Assembly or Seals, Oil Feed -- Replace
Servo, Intermediate/4th -- R&R or Replace
Servo, Low/Reverse -- R&R or Replace
Valve, Oil Level Control -- Replace
Cover, Side or Seals -- Replace
Solenoid, Check Ball and Wiring Assembly -- Replace
Solenoids, A/B Shift -- Replace
Solenoid/Valve, 3-4, 4-5 Shift Control -- Replace
Seal, Manual Shaft -- Replace
Solenoid, Transmission Kickdown Shfit -- Replace
Switch and/or Seal, 3rd Clutch Pressure -- Replace
Switch and/or Seal, 4th Clutch Pressure -- Replace
Accumulator, Forward -- R&R or Replace
Manifold and/or Gasket, Clutch Pressure Control Solenoid -- Replace
Cover and/or Gasket, Valve Body -- Replace
Pump Assembly, Transaxle Oil -- R&R or Replace
Valve, Pressure Regulator -- Replace
Valve Assembly, TCC Apply -- R&R or Replace
Old 03-03-2009, 08:40 AM
Transmission/Transaxle Continued
Wiring Harness and/or Solenoid -- Harness Assembly -- Replace
Wiring Harness and/or Solenoid -- 1-2 Shift Solenoid -- Replace
Wiring Harness and/or Solenoid -- 2-3 Shift Solenoid -- Replace
Wiring Harness and/or Solenoid -- TCC PWM Solenoid -- Replace
Wiring Harness and/or Solenoid -- (On/Off) Solenoid -- Replace
Solenoid, 3-2 Control -- Replace
Valve Body, Transmission/Transaxle -- R&R or Replace
Accumulator, 3-4 -- R&R or Replace
Wiring Harness ans/or Solenoid, Torque Converter Clutch Solenoid -- Replace
Solenoid, 1-2, 3-4 Shift -- Replace
Valve Assembly, Lower Control -- R&R or Replace
Spacer Plate and Gasket Assembly -- Replace
Plate, Lower Channel -- Replace
Servo Assembly, Intermediate -- R&R or Replace
Servo Assembly, Reverse -- R&R or Replace
Servo Assembly, Forward -- R&R or Replace
Servo Assembly, 1-2 -- R&R or Replace
Servo Assembly, 2-4 -- R&R or Replace
Pawl, Shaft, Rod or Spring, Parking -- Replace
Detent Spring and Roller Assembly -- Replace
Piston and/or Spring, Accumulator -- Replace
Piston and/or Spring, 1-2 Accumulator -- R&R or Replace
Accumulator, Reverse -- R&R or Replace
Servo, Front -- R&R or Replace
Servo, Rear -- R&R or Replace
Mount, Transaxle -- Front -- Replace
Mount, Transaxle -- Center -- Replace
Mount, Tranmission/Transaxle -- Both -- Replace
Bracket, Transaxle Mount -- Replace
Bracket, Transaxle Mount -- Right -- R&R or Replace
Bracket, Transaxle Mount -- Left -- R&R or Replace
Brace, Transaxle Support -- Replace
Seal, Transaxle Shaft Oil -- Right -- Replace
Seal, Transaxle Shaft Oil -- Left -- Replace
Seal, Transaxle Shaft Oil -- Both -- Replace
Sleeve and/or Output Stub Shaft (Right) -- Replace
Gear and/or Output Shaft Bearing, Speedometer Drive -- Replace
Shaft, Transmission/Transaxle Output -- Replace
Sleeve, Output Shaft (Left) -- Replace
Converter Assembly, Transmission/Transaxle -- Replace
Seal, Converter Hub Lip -- Replace
Shaft Assembly, Manual Detent Lever -- Replace
Housing, Transmission Coverter -- Replace
Gasket, Transaxle Case to Housing -- Replace
Gear Shaft, Bearing and/or Spacer, Reverse Idler -- Replace
Seal, Tranmission/Transaxle Converter -- Replace
Seal, Transmission/Transaxle Oil Pump -- Replace
Pump and/or Gasket, Transmission/Transaxle Oil -- Replace
Pump, Transmission/Transaxle Oil -- R&R or Replace
Pump Gasket and/or O-Ring Seal -- R&R or Replace
Valve Assembly, Control and Gasket -- Replace
Spacer Plate, Check Ball and Gasket -- Replace
Gear Assembly, Planetary -- Replace
Gear Assembly, Counter Drive -- Replace
Shaft, Input -- Replace
Front Support Assembly -- Replace
Clutch Pack, 4th -- R&R or Replace
Overdrive Unit -- R&R or Replace
Clutch, Direct -- R&R or Replace
Clutch, Forward -- R&R or Replace
Band, Intermedate -- R&R or Replace
Clutch Assembly, Forward -- R&R or Replace
Shaft, Turbine -- Replace
Shaft, Main -- Replace
O-Ring, Turbine Shaft -- Replace
Shaft, Pump Drive -- Replace
Cover and/or Gaskets, Side -- Replace
Housing and Drum Assembly, Reverse Input -- R&R or Replace
Clutch, Reverse Input -- R&R or Replace
Clutch Assembly, Direct and Reverse -- Replace
Filter and Seal, Oil -- Replace
Pumps. Oil -- R&R or Replace
Valve Assembly, Upper Control -- R&R or Replace
Input Housing and Turbine Shaft Assembly -- Replace
Clutch, 3-4 -- R&R or Replace
Sprag, Forward Clutch -- Replace
Clutch, Overrun -- R&R or Replace
Band, 2-4 -- R&R or Replace
Carrier Assembly, Input -- R&R or Replace
Reaction Gear Set and/or Reaction Sun Shell -- Replace
Carrier Assembly, Front -- Replace
Clutch Assembly, Second Coast -- Replace
Clutch Assembly, Second Brake -- Repalce
Clutch, Low and Reverse Roller Clutch -- R&R or Replace
Support, Low and Reverse -- R&R or Replace
Plates, Low and Reverse Clutch -- R&R or Replace
Carrier, Reasction -- R&R or Replace
Shaft, Output -- R&R or Replace
Low and Reverse Clutch Piston Assembly -- Replace
Direct and Intermediate Clutch -- R&R or Replace
Band, Front -- R&R or Replace
Shaft, Sun Grear -- R&R or Replace
Sprag Assembly -- Intermediate Clutch -- Replace
Support, Center -- R&R or Replace
Gear Unit Assembly -- R&R or Replace
Band, Rear -- R&R or Replace
Gear Assembly, Output -- Replace
Gear Assembly, Front Differential Transfer Drive -- Replace
Gear Assembly, 1-2/Reverse Carrier -- Replace
Gear, Front Internal -- Replace
Drum, 4-5 Clutch -- Replace
Band Assembly, Third Gear -- Replace
Clutch Assembly, Second -- R&R or Replace
Clutch Assembly, 1-2-3 and 4 -- R&R or Replace
Clutch Assembly, 4-5 and/or 6 -- R&R or Replace
Clutch Assembly, 3-5 and Reverse -- R&R or Replace
Housing Assembly, 1-2-3-4-5 Clutch -- Replace
Gear, Input Sun -- R&R or Replace
Plate, Channel -- Replace
Gasket, Channel Plate -- Replace
Accumulator, 1-2; Piston, Seal or Spring -- Replace
Accumulator, 2-3; Piston, Seal or Spring -- Replace
Accumulator, 3-4; Piston, Seal or Spring -- Replace
Spacer Plate and/or Gasket, Case Cover Assembly -- Replace
Cpver and/or Gaskets, Transaxle Case -- Replace
Sprocket, Drive -- Replace
Sprocket, Driven -- Replace
Link Assembly, Transaxle Drive -- Replace
Support and Seals, Drive Sprocket -- Replace
Harness Assembly, Control Wire -- Replace
Clutch Assembly, Fourth -- R&R or Replace
Support, Driven Sprocket -- Replace
Clutch, Second -- R&R or Replace
Clutch, Third -- R&R or Replace
Roller, Third Clutch -- R&R or Replace
Band, Reverse -- R&R or Replace
Clutch, Input -- R&R or Replace
Sprag Assemly, Input -- Replace
Drum, Reverse Reaction -- Replace
Reverse Clutch and/or Housing Assembly -- R&R or Replace
Actuator Assembly, Park Lock -- Replace
Sprag, Second Clutch -- Replace
Band, 4th -- Replace
Band Assembly, 2-1 -- R&R or Replace
Guide and Seal, Park Lock Actuator -- Replace
Carrier Assembly, Input and Reaction -- R&R or Replace
Gear, Reaction Sun -- R&R or Replace
Support Assembly, 1-2 -- R&R or Replace
Band Assembly, Forward -- R&R or Replace
3rd Clutch Hub and Reaction Sun Shaft -- Replace
Shell, Reaction -- Replace
Carrier Assembly, Reaction -- Replace
Reaction Sun Gear and Shell Assembly -- Replace
Clutch, Intermediate One-Way -- Replace
Input Shaft/Third Clutch Housing and/or Seals -- Replace
Carrier Assembly, Intermediate -- Replace
Clutch Assembly, Reverse Input -- R&R or Replace
Clutch, Forward/Coast -- R&R or Replace
Band, Intermediate/4th -- Replace
Shaft, Final Drive Sun Gear -- Replace
Clutch Assembly, Intermediate -- Replace
Support, Forward Clutch -- Replace
Hub, Direct Clutch -- Replace
Hub, Forward Clutch -- Replace
Clutch, Low and Reverse -- Replace
Clutch Assembly, Direct and Coast -- R&R or Replace
Housing, Direct & Coast & Input Shaft -- Replace
Gear, Input Interanl and Forward Clutch Hub -- Replace
Clutch, Lo Roller -- Replace
Roller Assembly, Low Clutch -- Replace
Housing ASM, O/D Clutch -- Replace
Sprag Assembly, Forward Clutch -- Repalce
Carrier, Input -- Replace
Carrier Assembly, Output -- Replace
Gear, Input Internal -- Replace
Gear, Reaction Internal -- Replace
Hub, Intermediate and Overdrive and Reverse -- Replace
Band, Lo/Reverse -- Replace
Clutch, O/D Brake -- Replace
Clutch Assembly, Fourth -- Replace
Piston, O/D Brake -- Replace
Differential and Final Drive Assembly, Transaxle -- Replace
Differential and Final Drive Assembly, Transaxle -- R&R
Differential Side Gears, Pinion Shafts and Pinion Gears Transaxle -- Replace
Differential Carrier, Transaxle -- Replace
Gear, Speedometer Drive -- Replace
Case, Transmission/Transaxle -- Replace
Old 03-03-2009, 08:41 AM
Fuel
Sender and/or Pump Assembly, Fuel (Tank Unit) -- Replace
Sender/Pump Assembly, Fuel (Tank Unit) -- Right Tank -- Replace
Sender/Pump Assembly, Fuel (Tank Unit) -- Left Tank -- Replace
Sender/Pump Assembly, Fuel (Tank Unit) -- Rear Tank -- Replace
Lock-Off, High Pressure (Alternative Fuel Dedicated DNG/Bi-Fuel) -- Replace
Seal, Exhaust Pipe -- Replace
Gasket, Exhaust Manifold to Exhaust Manifold Pipe -- Replace
Seal, Front Exhaust Pipe -- Replace
Old 03-03-2009, 08:43 AM
2010 & 2011 Powertrain Coverage
2010 Cover everything above with these new EXCLUSIONS.
DATE: September 21, 2009
TO: All US GM Dealers, Service Directors, Warranty Administrators and Parts Managers
SUBJECT: Changes to the General Motors 100,000 Mile/5 Year Powertrain Warranty for 2010 Model Year Vehicles
This message is to provide information regarding the a few changes to the GM Powertrain Warranty for 2010 model year vehicles. Previous model year vehicles are NOT affected by these changes.
For model year 2010, General Motors is announcing a slight change in the components that are covered under the 100,000 mile/5 year limited warranty on all light duty cars and trucks. The Warranty and Owner Assistance Information booklets have already been updated with these changes in all New 2010 model GM vehicles.
The following items have been eliminated from the Powertrain portion of the coverage for 2010, however, they will continue to be covered for the entire length of the Bumper to Bumper Limited Warranty for all GM vehicles. Select components may also be covered by Federal or State Emission coverage. Please refer to the Labor Time Guide and Policies and Procedures (P&P) manual for further details.
1) The entire pressurized fuel system (in-tank fuel pump, lines, fuel rail, injectors and return line).
2) The Engine/Powertrain Control Module (ECM/PCM) and module programming.
3) The Transmission Control Module (TCM), Transfer Case Control Module and module programming.
4) The Throttle Body Assembly.
5) Clutch and Pressure Plate for Manual Transmission.
6) Sealed Wheel Bearing Assemblies or Hub and Bearing Assemblies (axle shafts, seals and bearings that are part of complete axle housings are still covered).
The following items have been added to the Powertrain portion of the coverage for 2010.
1) Engine oiling system including the hoses, lines and cooler.
2) Crankshaft Pulley.
3) Clutch Master Cylinder.
Old 12-06-2010, 08:27 AM
xzombiex66's Avatar
So the powertrain warranty covers the tensioner pulley is it needs replaced?
xzombiex66 is offline
Old 12-06-2010, 08:28 AM
xzombiex66's Avatar
I have a rattle coming from the pulley area and i thinking its a pulley making the sound, does it at low RPM. I guessing Tensioner...
Old 12-06-2010, 09:08 AM
Drive belt tensioner is not covered by power train.
Quick Reply: '07-'09 & '10-'11 Powertrain Parts Coverage List
