evap vent valve solenoid malfunction
Old 03-22-2009, 12:20 PM
Diskokid's Avatar
please tell me the location on car of this item how to remove and replace part thanks code po449 on my scanner tool how about a picture no the purge valve i know where that is thanks
Diskokid is offline
Old 03-22-2009, 01:05 PM
mistermike's Avatar
This should be covered under the 80,000 mile emission systems warranty.
mistermike is offline
Old 03-22-2009, 01:31 PM
Diskokid's Avatar
yeah but my car is a 2006 does that still apply i have 65,000 mi
Diskokid is offline
Old 03-22-2009, 02:05 PM
masterchief1112's Avatar
pretty sure the 80K on emissions is required by law.
masterchief1112 is offline
Old 03-24-2009, 07:12 AM
fastsuv's Avatar
I had the same problem a few months ago and ChevyMgr said its not covered. I believe the only emissions stuff covered is the catalytic converter and the PCM.
There is also a service bulletin on the P0449 code. Apparently a pin in the underhood fuse box can push out and kill the +5V to the valve, setting the code.
In my case, I unplugged the connector at the valve and the re-connected it and all is fine now.
The vent valve is on the evap canister under the car by the rear axle, between the spare tire well and the gas tank.
If you do need to replace the valve, it comes off easily.
Here is alink to the thread where the service bulletin is posted:
https://www.chevyhhr.net/forums/problems-service-repairs-42/p0449-code-20547/
Steve
fastsuv is offline
Old 04-18-2009, 01:13 PM
srlmort's Avatar
So i'ts not covered under the Chevy warranty?
ugh!
srlmort is offline
Old 04-18-2009, 02:57 PM
c2vette's Avatar
I believe that emissions warranty is as follows: Under the California Emissions Warranty, all emissions related parts are covered for 3 years or 50,000 miles, and a vehicle-specific list of more expensive emissions related parts is covered for 7 years or 70,000 miles. In addition, the 8 year or 80,000 mile coverage for the catalytic converter and engine control unit required by Federal law
also applies. So it appears you are out of luck. Of course newer cars with the 100,000 mile warranties are covered for any type of failure.
c2vette is offline
Old 03-26-2010, 01:03 PM
ysm2's Avatar
Hi all, I have a 2007 HHR with 16,000 miles and a code P0449 which I can't clear,I have replaced the gas cap and solonoid vent valve and checked the connector at the fuse box with no luck in fixing it, any suggestions?
ysm2 is offline
Old 11-11-2012, 01:33 PM
Hucko3's Avatar
Does anyone know a part number for this from like Rockauto or something? I picked one up from autozone and the power connectors are different....
Hucko3 is offline
TiggersHHR
"How To" Tutorial Library
60
03-31-2024 08:56 AM
nrodwal
03-14-2021 02:12 PM
tomdel50
06-26-2015 08:46 PM
2007HHRLT
02-08-2013 07:17 PM
Quick Reply: evap vent valve solenoid malfunction
