coolant temperature readout question??
i find that if i let my hhr warm up in the morning that my coolant readout is
--- degrees f has this happened to anyone else?
please let me know thanks
fabio
fabio
yes the thermostat guage is flat also....only when i let it idle for 10 min or so and not every morning either no check engine light though
If you just bought it, is there not a warranty that would cover this repair? It is a fairly easy repair and there are several threads, some with pictures, right in this section....
"Problems/Service Issues"
i had the same problem too. i had it scanned and found out it was the coolant temp sensor. i replace that and reset my check engine light, and it hasnt came back on since. and the gauge is working just like it normally does too.
