a little red paint and a piece of sandpaper =
thanks
yeah i took it off and stripped all the bolts and brackets off of it. probably 20 min to take off and put on. 3hrs for paint to cure enough to block sand the ecotec on it. simple job just dont be in a hurry when you do it and be careful with your gaskets. I wanted a red close to the old lt4 intakes so i used vht brake paint from autozone. $7.50
Originally Posted by john 11
Crowbar
That is just beautiful. I can tell you took very special care in selecting the colors. Great Job. I'll bet it even looks better in person.
john 11 we need a mid state meet
Originally Posted by GDZHHR
What did you do to prep the surface?
sprayed the whole thing with brake parts cleaner &
wiped it off with a rag
scuffed the whole piece with scotch brite pad real good
wiped down again this time with preps all cleaner (autozone)
sprayed
hope this helps
