2.0L Performance Tech Section OPEN
Old Aug 16, 2007 | 06:55 PM
JonyyB's Avatar
Technical discussions only! All off topic will be removed
Old Aug 17, 2007 | 11:29 AM
cperez1217's Avatar
Does the new ss have a limited slip? Also will the ingall stiffy work on that block
Old Aug 17, 2007 | 11:43 AM
monza's Avatar
the info on it said that it would be available - read an option...
i'd guess that a limited slip would hold at least a 1500 premium... if not 2k...
Old Aug 17, 2007 | 12:09 PM
en0oNmAI's Avatar
but with the SS coming with the DIC that offers a "launch control" option standard why would you need an LSD? It might help in cornering but straight line acceleration.. LSD wouldn't make a huge difference given the capability of the computers running today's automobiles. The fastest Cobalt in Tucson right now doesn't have an LSD and left a Lancer Evolution at the tree and just kept pulling.
Doing a road course or using it in the snow?? then yes, by all means get the LSD.
Old Sep 3, 2007 | 03:21 PM
bluestreaker's Avatar
Like LSD
I have one wheel spin on asphalt in the wet all the time if I poke it a little too hard. Would always opt for LSD when offered. And, do drive my HHR in the winter, nice on ice and show.
Old Sep 17, 2007 | 06:07 AM
AndrewGS's Avatar
LSD should only be about $750. It would work in conjunction with the launch control.
Old Jan 14, 2008 | 10:49 PM
SSoLong's Avatar
Local dealer had a 5 speed SS with LSD option $495. I've looked at 20 or so automatics and never seen LSD. It would be a good addition to the launch control, 2 tires grip better than one.
Old Mar 2, 2008 | 03:59 PM
2007OrangeHHRLT1's Avatar
The SS does come with the launch control stock...I have only found it one time on my car...I would try it out and let you know how it works...I also have the limited slip option works great!!!
Old Mar 16, 2008 | 10:54 AM
mistermike's Avatar
Anyone have the RPO code for LSD option? I wouldn't consider a high torque setup without one. Launch control and stability control have nothing to do with LSD. Launch control simply governs engine behavior during launch in much the same way torque management works to protect an automatic transmission from a premature demise. Without LSD, launch control will pull back torque more aggressively once that one wheel drive starts to lose traction.
Old Mar 16, 2008 | 01:29 PM
Cpt.Carnage's Avatar
RPO codes for the SS LSD
G85 - LIMITED SLIP DIFFERENTIAL (REQ: MM5 5-Speed Manual Trans)
