LF/WTB: plug and play 3bar map kit
WantedEngine - Electrical
Description:
looking for the revised/plug n'play 3bar map kit. let me know price and details please.
You looking for good used set or a new set like these from ZZP
https://zzperformance.com/products/gm-stage-1-sensors
Also remember to re-program the ECU because of the sensor change:
ECU Programming
In HP Tuners,
MAP sensor linear to 65.89kPa
MAP sensor offset to -6.35kPa
Boost sensor linear to 65.89kPa
Boost sensor offset to -6.35kPa
ECU Programming
In HP Tuners,
thanks, for the reminder 2005HHRauto. i currently am deciding if paying to upgrade to the 3bar be worth it on the stock K04 for the extra 2-3psi since i read the K04 runs out of breath at around 23/24psi. car's currently running the max 2bar at around 21/22psi.
