2.0 LDK Build
Old Aug 18, 2016 | 07:34 AM
  #141
DrLoch's Avatar
I like the cover myself. It gives a different look.
Old Aug 18, 2016 | 08:19 AM
  #142
I like the cover. Cleans up the look.
( except for the hands/camera reflection in the last picture. )
One question though. How is the air filter assembly going to be mounted ? Will the cover interfere with it ?
Old Aug 18, 2016 | 08:28 AM
  #143
Powermizer's Avatar
Haha, one picture had my pretty face in it. sorry took it out.
No interference, because it's a sky. Air filter is in front of car.
I was thinking the cover may break up some of the red. I was planning on coating the compressor housing red too.
Old Aug 18, 2016 | 10:52 AM
  #144
Nice cover, but I'm thinking it might cause heat issues reflected back into the head!!
But hey I'm not one for LS7's and their engine covers.
Is it possible to change those mounting bolts to polished stainless steel button heads?
Old Aug 18, 2016 | 11:12 AM
  #145
Powermizer's Avatar
I appreciate what your saying about heat. I am not worried about it. Funny thing is, on the Sky they put the same foam as covering the injector pump over the whole valve cover then the plastic engine cove over that.
As far as bolts. what I am using are studs with acorn nuts. I agree I need something more shiny! Thanks
Old Aug 18, 2016 | 11:54 AM
  #146
DrLoch's Avatar
Shiny is good
Old Aug 18, 2016 | 12:07 PM
  #147
Hard to see in pictures, yes you would be limited to shine!
For my 2.2 K&N air box , the install kit had studs to thread into the valve cover then long nuts and bolts to screw in from the top
Check pictures 12 & 13 in this in page 2 of 2
http://www.knfilters.ca/instructions/63-3056_inst.pdf
Old Aug 18, 2016 | 10:46 PM
  #148
Powermizer's Avatar
Thanks Oldblue! After you showed the screws I was thinking about some threaded spacers. I will search the spacers Friday. Then I just need to find the polished button heads. That will look much better. Thanks again.
Old Aug 19, 2016 | 03:57 PM
  #149
Powermizer's Avatar
here is what i came up with.
Bolts I found, couldn't find polished ones.
I had to polish the bolt heads and washers myself.
Installed. Thanks Oldblue! Much cleaner look
House cleaning would be nice. Thanks Oldblue!
Attached Thumbnails 2.0 LDK Build-20160819_141252.jpg   2.0 LDK Build-20160819_141408.jpg   2.0 LDK Build-20160819_142244.jpg   2.0 LDK Build-20160819_144004.jpg
Old Aug 19, 2016 | 04:39 PM
  #150
Man, that looks sharp!! Can't wait to see it in the car!
