BOV help
Old Aug 5, 2011 | 10:07 AM
jas89tta's Avatar
BOV help
What needs to be done in order to install a BOV? I'm looking to have on installed I'm running the stock turbo but unsure what I need to get.
Old Aug 5, 2011 | 10:14 AM
bartSS's Avatar
Originally Posted by jas89tta
What needs to be done in order to install a BOV? I'm looking to have on installed I'm running the stock turbo but unsure what I need to get. Do you need a reprogram to keep the computer happy or will it work fine without a reprogram.
Dejon intercooler piping with a BOV flange welded on.. blockoff plate and a tune... let me know if you want to know how to hook it up... do not run it if youre not getting tuned
Old Aug 5, 2011 | 12:11 PM
rallycobalt06's Avatar
i honestly highly recommend just sticking with the stock bpv setup. there's nothing wrong with it and doesn't require a tune.
yes you read that right, a bov requires a tune.
but if you absolutely insist that you want it then here's a parts list to do a PROPER bov setup.
bov (obviously)
hot side charge pipe with bov flange
bpv block off plate
cold side charge pipe with MAF relocate kit
custom tune
Old Aug 5, 2011 | 12:20 PM
bartSS's Avatar
Rally the maf relocate isnt necessary dood... i dont have it :)
Old Aug 5, 2011 | 12:34 PM
jas89tta's Avatar
Thanks for the reply. That's what I thought and sounds like more trouble than it's worth. Also I was reading about a forged BPV should I consider this as a option? If anyone has one installed did it change the way the car sounds?
Old Aug 5, 2011 | 01:53 PM
RobSSTurbo's Avatar
I installed my bov without maf relocated I have never had any problems. I didn't need a tune either had the GM stg.1 tune in there it's work just fine.
Old Aug 5, 2011 | 02:00 PM
bartSS's Avatar
Thats what you think... check your fuel trims while driving and watch them spike on shifts
Old Aug 5, 2011 | 02:24 PM
i had the Forged BPV, didn't notice any difference. so i sold it. it's not a bad piece, just unnecessary unless your stock bpv goes down (which is rare).
if you're looking for more noise, get a new hot side charge pipe, it'll help a little bit.
i know my stock bpv is quite loud.
what are your LTFT's looking like? you might not notice it but it's probably not liking it.
Old Aug 5, 2011 | 06:05 PM
ATLsilverSS's Avatar
intake is the best way to hear the bypass valve...........yeah i know nobody makes an intake and the stock one is the best option yada yada...
not directed at you rally....just know its coming from someone
Old Aug 5, 2011 | 06:44 PM
RobSSTurbo's Avatar
ill check them but i dont remember seeing any spikes but i make sure may have already taken care of it when i tune it last weekend. ill check my old logs too.
