Motorh-Ed |
02-25-2010 10:50 AM |
Like to say thanks to everyone that replied. I am going with the idea that its not so much a torque steer problem as it is a loss of traction problem. I have tried to driver position myself to be as confortable as I can be and not be jerky with the wheel when the left right thing happens. Guess I have to wait for warmer weather and maybe a new set of softer compound tires. One of you guys mentioned traction bars. Wheel hop could be it too. I have been abusing this thing in 30 degree weather, I am going to wait for warmer weather and reduce tire pressure to 28-29 lbs. and see what that does. One last thing, switching the comp mode off was a solution for some one out there. I am under the impression that when in comp mode the ecu is running a differant map, turbo pressure, static, dynamic, variable timing, maybe fuel pressure I don't know what else, there by resulting in More Horsepower more torque. That would explain turning off the comp mode helped solve torque steer for him. GM engineers put a lot into this little motor and its computer controls and safe gaurds and I expect that I should be able to flail it to its fullest potential. Thanks again for your time.
