Great customer service -forge motorsports
Old Oct 5, 2012 | 09:07 PM
XtremeSS's Avatar
Well, when I used the dejon spring, it threw that code but only happens when air is not dense(humid/hot conditions). The dejon spring also caused excessive turbo "flutter" in theses conditions. I think joe is on the right path here. Lube that biotch. It seems the valve is not opening fast enough.
Old Oct 6, 2012 | 10:18 AM
andyb's Avatar
Question
what kind of lube? it's got some red grease in there now.
Old Oct 8, 2012 | 01:26 AM
XtremeSS's Avatar
Mobil 1 grease
Old Oct 8, 2012 | 06:19 AM
08SSREDHHR's Avatar
Yes it needs lube! I just made a thread on this. My car kept throwing a p2261, took the forge out and completely apart and the grease was black and clumpy. I cleaned the whole thing and regreased with mobil 1 synthetic red grease. Its not the spring causing the cel I had both springs and kept throwing the CEL, then after reading threads on CSS.net others have said it gets stuck when it needs regreased.
Old Oct 8, 2012 | 11:49 AM
andyb's Avatar
when i get the green spring & change it out, i will look at greasing it, but i've only had it installed for 3 months & it popped the p2261 code from day 1.
Old Oct 8, 2012 | 06:14 PM
08SSREDHHR's Avatar
Thats weird, mine just started and ive had it for about 8 months. Greased it and CEL is gone.
Old Oct 15, 2012 | 01:33 PM
andyb's Avatar
Thumbs down
well, so much for "great customer service". what a bunch of *******s. called forge a couple weeks ago & told them ever since i installed their valve, i get a check engine light daily. the 1st guy said no problem, i'll send you a green spring. 1 week later, call them again & get another guy, who says the 1st guy isn't in & there's no record of them sending anything to me. the 2nd guys says he'll send me a green spring. another week goes by & no spring at all. so calling out for SS FAN, if your offer still stands, i can use that green spring!
Old Oct 15, 2012 | 06:07 PM
XtremeSS's Avatar
Dude, grease it. The longer you wait, the bigger chance you have of damaging your turbo.
Old Oct 15, 2012 | 08:26 PM
08SSREDHHR's Avatar
Its not the spring...
Old Oct 15, 2012 | 09:03 PM
These guy's have a good point, I'm going to grease mine just as preventative maintenance. I have two green ones in my box 0 springs, I only have one SS so you can have one pm me where to send it.
