Hahn (BSR) Auto Tune installed.
Old Sep 16, 2008 | 05:49 PM
  #61
damronjr's Avatar
Originally Posted by OCMerrill
This particular tuner is a hand held module that plugs into your diagnostic port. It basically saves your old info and uploads the modified info. You can revert if need be.
That's what I was gathering, so it's like the Hypertech I had for my S-10, but it seems this is programmed only 1 way, so you can't make adjustments like you could with the Hypertech. Still cool, pricey, but cool. The Hypertech was only like $350, and you change your wheel/tire size for the speedo, tire rating for top speed limiter adjustment, change shift points for the AT, etc...
Old Sep 16, 2008 | 06:56 PM
  #62
SSROADSTER's Avatar
Originally Posted by patrick49
Thanks for the continued updates...this is something I'm considering as a post-Christmas present to myself if I manage to pull in enough money in the mean time and I think it will be a safe enough investment on the car.
A couple probably dumb questions - when you say you had the trans loaded at 1k RPM, what does that mean?
How does the I setting help eliminate wheelspin?
never a dumb question, loading the trans to 1k means I just keep my foot on the brake (brake torque) and brought the r's up to 1k, and then did WOT...
The "I" setting does not eliminate wheelspin, it's just the way I was playing around with the runs, there was no set pattern, just experimenting...
Originally Posted by foolmoon_design
After following your thread, am I correct to guess that utilizing the L1 and I settings for the 4-speed auto is actually getting better results than D while using the tune? Also, the Traction Control in the off position, or Comp mode delivers the best results?
just playing around with the trans......IMO the engine responds better in the "L", or "I" position, rather than the "D", (and again just my thoughts) it seems to be "geared" different than in "D". using "D" gets great response, don't get me wrong, but I think it shifts sooner, although I haven't done a WOT in "D" yet....
the TC is off, and I always use "LAUCH CONTROL" for any tests
following this thread you have seen that there are different alternatives that are coming from different companies. check them all out before you buy anything, to make sure you get the correct product for your needs....
Old Sep 16, 2008 | 07:07 PM
  #63
damronjr's Avatar
To be honest with you, I want the best product with the best gains, regardless of price. If I have to pay more I would rather do that than buy something else b/c it is cheaper and feel like I could have had more if I just spent a little more. It would be nice to have a side-by-side comparison of each of the tuners, what they are each available for, what gains you should expect from each, and what options each comes with.
Old Sep 16, 2008 | 07:18 PM
  #64
SSROADSTER's Avatar
I hear you there!!! As I have said before, I am very happy with this tune, it does all that I want for now....
The SS drives as normal as it did w/o the tune, but when you get into it, it is a whole 'nother vehicle....
Some of the guys do have HP, but I haven't heard of any SS owners getting Wester's yet. It would be a good comparison, and I am sure more companies will be coming out with their software products soon...
Old Sep 16, 2008 | 09:05 PM
  #65
405HP_Z06's Avatar
Tom,
Thanks for posting the detailed information on the Hahn/PPC tuner, great review!
Old Sep 17, 2008 | 09:18 PM
  #66
SSROADSTER's Avatar
Originally Posted by 405HP_Z06
Tom,
Aaron, thanks for the compliment!!! glad you are enjoying the read!!!
things are getting more interesting now that GM has included the SS w/auto in the upgrade kit, anxious to see what it entails.....
Old Sep 18, 2008 | 05:07 PM
  #67
camaro98z28's Avatar
There was a comparison with different tuners in Performance Chevy mag a few months ago. Might want to look for the article to see what these tuners offer and get an idea of what is coming for the HHR. All in all HP tuner would be the best idea but, you would have to either learn it or pay someone to tune your HHR for you.
Old Oct 1, 2008 | 08:47 PM
  #68
jetttstream's Avatar
Thumbs up
Automatic with lauch control? Someone please explan.
I read the whole first post like he was driving a manual tranny..and then to **** my pants to see he is driving an automatic!
Wow!!!!!!!!!!!
I need more info on these little rockets!!
Can the auto's now keep up with the 260hp manuals?
-Mike
Old Oct 1, 2008 | 08:57 PM
  #69
AaronSS's Avatar
Yes, automatics have launch control. You engage the brake to use it, if I remember correctly. They'll light 'em up off the line too. I did it on a test drive. But don't bother asking your salesman about it, because most don't know that launch control exists.
Welcome to the boards, by the way.
To answer your question, I would think a tuned automatic would definitely keep up with a stock MT nicely, and maybe take the kill. They're only down 10hp in 3rd gear stock for stock. The 235hp in first and second is what's advertized and talked about, but it's not so bad really.
Old Oct 1, 2008 | 09:08 PM
  #70
Red face
Nice info and Thanks!!!!
I'm going to drive one of these! Tomorrow if I can!!
At least when I roll in with the TBSS they'll know I mean business!
Time for a MPG upgrade! hah.
-Mike
