Hot-side IC Pipe
Old Jan 11, 2011 | 06:40 PM
  #31
foolmoon_design's Avatar
Originally Posted by asanti
Foolmoon, define the recommended maintenance the Forge piece needs? I'm looking at geting one and from what I read at the CobaltSS forum it needs to be greased/oiled @ install correct? If I have to periodically tinker with it and re-oil it like a K&N filter that may FUBAR my plans for purchasing one.
Later
Allex
The company recommends servicing, or at least inspecting it at every oil-change. They suggest removing the vac line and doing a pen test to see if the unit has free movement. If not then pull it out and lube with Mobil 1 Synthetic lube.
I tinker with my car more and more, this may not be an issue, especially if roped in with your regular oil-change. I can't imangine it taking more than 20 minutes to service.
The advantage to this part is no rubber diaphram, and 4 "tune" springs with diffrent coil rate. They have a sleeve for this unit too, which allows the BPV(According to Garret its a BCV-bypass control valve) to vent to atmosphere, but Forge thinks there might be a clearance issue, they haven't heard back yet from the CSS tester, for sure. On the cobalt the BPV-BOV was hitting the CAI... Since the HHR SS STILL DOESN'T HAVE A TRUE CAI, we might be able to run this. I was gonna just pull the BCV and put a Gready BOV in its place then OVERBOOST turned me onto this option. But you know the rules not a supporting vendor, so everone has to research their own prices, availability, etc. Unless we could get TTR to maybe carry these?
Old Jan 13, 2011 | 12:41 PM
  #32
asanti's Avatar
Would the MAF have to be relocated if the vent-to-atmosphere feature works for us? Or is that just w/ the aftermarket BOV's that are used in the charge pipes (like Dejon's)?
Later
Allex
BTW anyone else see the new Borg Warner turbos at SEMA? Really trick stuff!
Old Jan 13, 2011 | 02:53 PM
  #33
bartSS's Avatar
Later
Allex
You dont have to. My maf isnt relocated. But please tune for the BOV if you will be putting one on because the car will run like total poop if you do not.
Old Jan 13, 2011 | 05:48 PM
  #34
asanti's Avatar
Thumbs up
Definitely Bart. I'm looking to get the tune once the weather warms up.
Later
Allex
Cat Man HHR
2.0L Performance Tech
Oct 15, 2014 04:09 AM
bodywerks
19
Jan 10, 2009 09:23 AM
