Installing an Oil Catch Can
Old 04-22-2019, 01:21 PM
  #401
132,266 miles, another drain.
15 oz. turbo-side, and 16 oz. intake-side.
135,240 miles, another drain.
I forgot to post the last drain, and I didn't record the mileage. Pretty sure I was well over my 1,200 mile goal. Probably around 1,700-1,800 miles.
16 oz. turbo-side, and 23 oz. intake-side.
So now I'm guessing around 1,200-1,300 miles this time.
1 oz. turbo-side, and 4 oz. intake-side.
It looks like I have a lot less restriction in both systems now, not much caught at all. I'll probably try to clean and reinstall the 5um sintered bronze filters(I had removed them when I rebuilt the catch cans).
RJ_RS_SS_350 is offline
Old 06-14-2019, 04:08 PM
  #402
139,214 miles. I have retired my intake-side catch can. The bottom of the bowl blew out again. I ordered this can from an eBay seller.
https://www.ebay.com/itm/500ml-Cylin...-/163671086805
I first drilled and tapped the bottom of the bowl, for the fitting that drains to the collection tank.
I purchased a 1" PVC coupler at the hardware store. The inside of one end had to be sanded(quite a bit) so that it would fit tightly over the supplied filter holder. Once I got it sized and forced all the way on, then I grinded down part of the outside of the PVC coupler, so that the bowl would thread back on.
I needed 1" of pipe to extend from the coupler, to better achieve chambering of the catch can.
Then I packed the 1" pipe with the stainless pot scrubber pad material, packed more pot scrubber material around the 1"pipe, and carefully threaded on the bowl.
I was able to use the same mounting bracket as the previous can used, with only slight modification. I punched out the center knockout(remember, it is a modified 4" electrical junction box). Then I drilled out another hole to 1/4". I bought a 6mm cap screw and split washer at the hardware store. Replacing the unneeded dipstick, this screw went through the 1/4" hole(with pipe thread sealant) and became a mounting screw.
I used one of the supplied fittings through the knockout hole as another mounting screw, where they show the(unwanted) breather. More sealant and a cap. Replaced some lines for length, rerouted other lines, done.
Drained both collection tanks for baseline. Really nothing in either one. We'll see how this goes.
Old 06-14-2019, 04:33 PM
  #403
Good follow up, I hope this takes care of the issue.
Thanks for the pictures, much better to comprehend, what went where.
Oldblue is offline
Old 08-02-2019, 08:00 PM
  #404
140,635 miles, another drain.
Only 1/2 oz. turbo-side, and 4 oz. intake-side.
So it seems that more fluid is getting past the filtration, without the sintered bronze filter in the system.
Old 11-06-2019, 05:03 PM
  #405
I drained the catch cans again, September 20. 143,237 miles.
4 oz. turbo-side, and 18 oz. intake-side.
Old 11-06-2019, 05:17 PM
  #406
I finally found a good replacement can for the turbo-side, and it showed up today, a day early!
https://www.ebay.com/itm/Silver-Oil-...-/123871893914
Finding a catch can with fittings in these positions was difficult, I must have looked through 40 pages at eBay.
Here's what came in the box.
I actually only used the 3 pieces in the front row. Pretty good chambering, there's a small piece of stainless pot scrubber in the black piece.
A trip to the hardware store for two fittings, 1/4" MPT x 3/8" hose barb. Reused the drain fitting, packed the can with the stainless pot scrubbers.
Installed the new can, done!
A moment of silence in recognition of the service that the other cans provided.....
Oh, I almost forgot. There was nothing in the turbo-side, and 16 oz. in the intake-side. 146,040 miles now. The bowl was broken on this old can also, there's quite a mess underneath the can. I won't have to worry about that anymore!
Old 11-06-2019, 05:37 PM
  #407
Salute!! Those cans gave their lives for a clean intake !
Nice replacement can for the turbo side.
Please keep us posted when you drain them.
Oldblue is offline
Old 05-24-2020, 05:59 PM
  #408
Many of you know that I installed a new engine in the SS.
https://www.chevyhhr.net/forums/prob...-engine-62561/
It's been about 1,200 miles(EDIT approx. 148,500) since then, so it's time to drain the catch cans. Oh, that's right, catch can, I removed the turbo-side can.
Zero. Not even a single drop. I even checked vaccum through the can, 19", same as displayed on the boost/vaccum gauge. So, there's no clog, the system is working properly.
That old LNF had some problems. I think I won't need to post in this thread anymore. Woo-Hoo!!
Old 05-25-2020, 02:05 PM
  #409
Cat Man HHR's Avatar
Did you look at the intake valves from the old engine, just to see if they were kept clean when you did that on it and then added the catch cans ?
Cat Man HHR is offline
Old 05-25-2020, 03:13 PM
  #410
I'll have to look, the intake manifold is off, installed on the new LHU. I'll try to remember to get some pics next time I'm over there at the shop.
Quick Reply: Installing an Oil Catch Can
