Chevy HHR Network
-   2.0L Performance Tech (https://www.chevyhhr.net/forums/2-0l-performance-tech-46/)
-   -   Low boost (https://www.chevyhhr.net/forums/2-0l-performance-tech-46/low-boost-67405/)
HHR SS 3M... Jan 25, 2025 02:03 AM
Low boost
After LAUNCH CONTROL = the gear shifts run through just fine = but at most, I'm only getting about 10psi of BOOST at full throttle = WHY???
2008 LNF I4 2.0L TURBO...
firemangeorge Jan 25, 2025 07:10 AM
Scan it for codes. There should be 1 or more related to low boost.
Post the code #’s here. Just the #’s. Not the description of the codes.
HHR SS 3M... Jan 25, 2025 08:18 AM
I have scanned my SS = NO CODES, & the CHECK ENGINE LIGHT is not on...
Oldblue Jan 25, 2025 08:24 AM
A member had a similar problem
https://www.chevyhhr.net/forums/prob...roblems-62281/
RJ_RS_SS_350 Jan 25, 2025 10:11 AM
You're only going to get about 14 psi from a stock SS. Maybe 15, depending on elevation. Then when you factor in that the cars with automatic transmissions have the power output limited in all gears except 3rd. Check this post https://www.chevyhhr.net/forums/hhr-...18/#post755762
HHR SS 3M... Jan 26, 2025 10:35 AM
I appreciate all the responses
https://cimg4.ibsrv.net/gimg/www.che...5647c2bb1a.jpg
