Originally Posted by xtremekirk
(Post 390717)
One minor problem is that since the system is so much larger then the stock one, I have a minor bump while going over rail-road tracks. I think that its hitting the drivers side spring mount. So I'm just going to heat up the one hanger and bend it so it has the proper clearance
1) Pipe is already close to the gas tank on the otherside of the Spring perch :red:? 2) Our muffler seems to sit lower in the back (barely noticeable) so when adjusting the hanger(s) try to refrain from over adjusting as the muffler could sit at a larger rake or tilt :eek:! Good Luck and Enjoy, |
If you're worried about heat you could use something like this:
http://summitracing.com/parts/THE-11620/ That's what I used for my crossover pipe. |
Originally Posted by 1Panel2NV
(Post 390748)
http://summitracing.com/parts/THE-11620/ That's what I used for my crossover pipe. Gonna order one this week! Just don't know how much of an issue the clearence is on the SS version since it is New with limited info..... |
| All times are GMT -5. The time now is 09:33 AM. |
