Map kits. Is this the same thing?
Hello,
I see two different map kits for sale online. They look the same but the price is miles apart. Oem Parts Depot.. GM stage 1 kit is $719 Cobalt, Solstice, HHR Stage Kit 19369111Hk While the ZZP.. GM Stage 1 Sensors is $115. https://zzperformance.com/products/gm-stage-1-sensors My take is one uses the GM ECM flash and the other uses a custom flash? Im new to the Turbo world.......Thanks. |
Yea the GM kit allows you to get the GM flash. WIth the ZZPerformance sensors you need to find someone who can change the sensor cals and updated the tune, i.e. HPTuners. If you know a good tuner getting the sensors from ZZP installing then changing the tune is the best bang for the buck. My tune before the upgrade was MUCH better than the GM tune but I needed the upgrade sensors.
