OEM Connectors for production MAP & TMAP Sensors
Does anyone have an idea of what the production MAP & TMAP sensor connectors are? Manufacture, part numbers?
There is a method to the madness here, just need some help help getting the part numbers of the exiting connectors that connects to the production sensors.
Dennis
Didn't have a chance to really explore this site but they may be able to help you. http://www.thefind.com/cars/info-sensor-connector
your dealer can get you the number of the connector/pigtail for the map/tmap just ask for it.
This is from the manual. These won't always match GM part #'s
Intake Air Pressure and Temperature Sensor (LNF) (TMAP) in the air pipe.
Connector Part Information
OEM: 12162187
Service: 19115673
Description: 4-Way F Metri-Pack 150.2 Series, Sealed, Pull to Seat (BK)
Manifold Absolute Pressure (MAP) Sensor (LNF)
OEM: 184032-1
Service: 19115590
Description: 3-Way F SSC Series, Sealed (BK)
OEM: 12162187
Service: 19115673
OEM: 184032-1
Service: 19115590
Would be nice if you could get a pigtail that looks like/mimics the stock oem MAP and T-MAP itself... then you could wire that thing to the new pigtails provided with the kit (in the comfort of your warm house) and just insert the resulting gender bender between the stock wiring harness and the new sensor...
That's what I'm trying to do. More info as I find it. Thanks Mgr, I'll try to run those numbers down.3-Way F SSC Series, Sealed (BK) who makes this one?
