OEM Connectors for production MAP & TMAP Sensors
Jumper Harness
Would be nice if you could get a pigtail that looks like/mimics the stock oem MAP and T-MAP itself... then you could wire that thing to the new pigtails provided with the kit (in the comfort of your warm house) and just insert the resulting gender bender between the stock wiring harness and the new sensor...
Too bad they don't make the male ends. I looked at my old sensors and cutting them up to make a male plug would really be messy.
Just think if they were made and GM included them in the stage kits instead of the connector with pigtails. How many kits have they sold so far..... ?
Just remembered when I got mine back they left the org sensors in the box on the pass floor..they cut the ends off right up to the sensors..making them unusable.....I thought this was odd..since I paid for them,why would they do that? Wanted to keep them for such a day if ever wanting to return to stock...
Overall, I am so happy with the upgrade, those are minor issues.
You are right, GM should have put the "adapters" in with both ends on each, would have made the install much easier and non of this crimp vs solder business would have ever been an issue. I believe the problem is that the kits are currently universal, just different tunes for each application. If they had made the adapters, there would be several different versions, which adds cost to them.... and then us. In hind site, at least with the HHR, would have been an overall savings do to the extra labor required. GM could also offer a sensor without the post for the HHR kit.
As you mentioned, even if the kit is universal if the connectors are the same for the other vehicles but the wiring is different, the answer is simple, use a different PN and make the wiring changes accordingly. An adapter would certainly save time on the install and it would alleviate the wiring mistakes that we have all seen, but from GM’s prospective this is a modification that by choice, the end user, us, is paying for, not them. At the moment they have bigger issues to resolve.
SwissHHR
Jul 29, 2014 01:36 PM
bigjacksauto
2.0L Performance Tech
12
Jul 4, 2012 01:13 PM
ShelbyVegas
Apr 16, 2010 04:58 AM
That's what I'm trying to do. More info as I find it. Thanks Mgr, I'll try to run those numbers down.
