Stage 1 Installed
Old Sep 10, 2010 | 04:01 PM
2010hhrss's Avatar
How much labor time at dealership to install
Old Sep 10, 2010 | 04:20 PM
*jerdog*'s Avatar
Congrats!!!! I think the diff we feel is the +8 #'s of boost!!!!
Try not to smile to much, it makes us look guilty of something! I came home after mine was done with huge smile and the wife said, "What, did you go to the booby bar" lol Enjoy!!!
Old Sep 10, 2010 | 08:58 PM
Rodney B's Avatar
About 2 hrs labor.
Old Sep 21, 2011 | 05:35 PM
XtremeSS's Avatar
How much psi is your gauge reading? Had mine installed but it won't boost past 18 psi and dealership had no answers as why I am not getting 20-24 psi. I also have a 2010 5sp.
Old Sep 21, 2011 | 06:01 PM
RobSSTurbo's Avatar
When did you get it installed?
Old Sep 21, 2011 | 06:09 PM
XtremeSS's Avatar
2 months ago
Old Sep 21, 2011 | 10:28 PM
wiggle the top wires, pinch and roll them 'tween the finger and the thumb. Then see if it will do 20lbs. If that works take it back and have they solder the connections. I did.
Old Sep 21, 2011 | 10:43 PM
XtremeSS's Avatar
Lol its funny you say that cuz I soldered the upper and lower map sensors last night to see if that would cure the problem and of course it didn't. I must say soldering the lower sensor wasn't as bad as I expected it to b after u disconnect two connections you can pull the harness closer.
Old Sep 21, 2011 | 10:48 PM
JeramieJJ's Avatar
TSB quotes 1.5 hrs if I remember correctly.
Old Sep 21, 2011 | 11:06 PM
Miltown SS's Avatar
Originally Posted by XtremeSS
How much psi is your gauge readingon ? Had mine installed but it won't boost past 18 psi and dealership had no answers as why I am not getting 20-24 psi. I also have a 2010 5sp.
18psi is completely normal depending on ambient air temp, sea level etc. I have the stage 1 as well and see 19psi normally in southeastern Wisconsin. Psi will change with the conditions mentioned above.
